Results 1 to 13 of 13
    FLAC Trooper ArcticFox's Avatar
    Jan 2003
    A theater near you
    5,425
    Need to find CD drive letter in DOS
    What's the command to list the drives and their letters in DOS?
    Thanks.
    Ultimate Member eweruk's Avatar
    Canada
    2,238
    Besides using FDISK to check the actual hard drives, no CDROM though, ummm....
    Are you wanting something like df in Linux??
    Canada
    2,238
    Are you using FAT32 or NTFS? You could try chkdsk but with NTFS, it does not give a lot of info on the drive sizes and assigned letters.
    Ok try this, fdisk /status
    Here are some more command listings
    http://www.generation.net/~hleboeuf/dos7comm.htm
    Ultimate Member nukes's Avatar
    Oct 2002
    Scotland, UK
    3,221
    There isn't, it just gets assigned the next availiable one after your FAT partitions.
    Unless you've specified something different on the MSCDEX command line, then it will just be that, so if you have 2 hard disk partitions that dos can read (C: and D the CDROM will be e:
    If you're using true dos (i.e. not in a dos shell inside windows) then you need to make sure you have the device driver loaded in config.sys and mscdex in autoexec.bat with the correct device identifier.
    If you got a floppy with the drive it probably has dos drivers on it, more likely than not any cdrom floppy would work for it so long as it isn't a cdrom which hooks onto the sound card rather than an IDE channel.
    _____
    NuKeS
    Canada
    2,238
    Yes, true there isn't but I imagine that ArticFox wants to be able to get some information from DOS to what is setup. We need some more info for sure to tell.
    First and easy, check WIN32 OS if installed
    Second, check fdisk in DOS to see what drives and partitions are setup and drive letters
    Third, type C: or D: or E: or F: to see what partitions are there.....
    Oct 2002
    Scotland, UK
    3,221
    If it's a true dos system (not 9x or NT) then you could use msd for system information. Its got most of the things you need to know - like memory, chips, drivers, drives in use and setup etc.
    I don't think it was included in the standalone versions of windows as it got replaced by msinfo.
    _____
    NuKeS
    Oct 2003
    Canada [Maritimes]
    1,268
    if you have dos 6.0 or upgraded from dos 4,5 or 6 you can go dos shell
    and see your drives
    when in dos type dosshell,press enter
    if you don't have it
    take a look at your dos disks, for a supplemental disk
    and copy all files to your dos directory
    Oct 2002
    Scotland, UK
    3,221
    lol, that wouldn't work. you'd need to EXTRACT them. I my dos 6.22 disks didn't have the shell in them. The last version of DOS I saw it in was 5.
    _____
    NuKeS
    Oct 2003
    Canada [Maritimes]
    1,268
    of course its not in dos 6.2
    you only have it if you upgrade from 4,5,or 6 to dos 6.2
    Jan 2003
    A theater near you
    5,425
    Sorry - thanks guy's we got it figured out. I was trying to put 98se on my laptop from XP Pro but I needed to format the drive first. Anyways I went ahead and tried "R:" as that's what my old eMachine's used for it's image installs, sure enough that's what it was.
    All that, and now I need to load Win2k on here again since 98se doesn't play well with my wireless connection.
    Mar 2009
    Australia
    Cool Confused all right about FDISK!=S
    Quote Originally Posted by eweruk View Post
    Man you are Confused! FDISK is a format disk command not a drive check command! Hope you mean no malice cos this command can wipe your drive! Maybe you should leave your confused comments to yourself man and take a course or something! =SS
    Oct 2010
    MAP cmd is the answer
    In the dos prompt type HELP. Shows you the avalable commands, one of which is MAP. Just type MAP and press enter.
    C:\Map
    then press enter
    It will show the partitions, drives, and CD\DVD drives with letters.
    ...Don't Mind Me... ShyguyXPC's Avatar
    USA
    19,361
    Quote Originally Posted by GeekITup View Post
    Replying to this comment a bit late, but, Sit Down Child And Shut Up!!!
    Maybe you need to keep your confused comments to yourself, rather than disrespect a regular member with a significantly higher post count than your own, Noob!!!
    Also the fact you needed to Reply to a posting that was 5 years old at the time, and disrespect them, adds to your Noobness.
    When using FDISK, you have the Option of Displaying the Current Partitions Information, which will Allow a Person to see what drives, are assigned to what letters. which is why I believe it was suggested initially. So maybe bother trying to get your facts straight before calling someone else out on something.
    Quote Originally Posted by userwhale View Post
    C:\Map
    then press enter
    Though Helpful... to a point, the Map Command is only a Recovery Console Command in Windows 2000 and XP, which should of been stated in the post, so people using Regular DOS or Windows 98 or earlier or Windows Vista Or newer "DOS" Command Prompt in the OS, and can't find the command at all, or get it to work right.
    Quick Google Search reveals this (as I didn't remember ever seeing that Command with Old School DOS, or even using the Command Prompts in Windows 95, 98, ME, 2000, XP, Vista or 7), its a Recovery Console Command Only.
    MS-DOS map command help
    Apart from the Noob who posted in here in 2009, I hope you realized this thread was from 2004, and the original Problem was resolved, Long ago...?
  1. pc won't start
    By sweeper2 in forum General Tech Discussion
    Last Post: April 13th, 2004, 08:00 PM
  2. scsi drive not working
    By billy00973 in forum PC Hardware
    Last Post: June 18th, 2003, 06:54 PM
  3. NTLDR missing - need to retreive work of drive
    By JON_M_A03 in forum Technical Support
    Last Post: June 15th, 2003, 01:28 PM
  4. DOS machines on network?
    By Eli in forum Networking and Internet
    Last Post: March 21st, 2003, 11:07 PM
  5. Ghost, and Win XP question.
    By Bopper in forum Applications and Operating Systems
    Last Post: February 21st, 2003, 02:35 PM
