Results 1 to 8 of 8
    Ultimas w00t! Mastah... vikeor's Avatar
    Warsaw, Poland
    6,444
    dloading in IE6.0
    for sum reason when i try to dload files using the built in IE dloader, it just opens them and i have to go a Save As. Is there a way i can change this so a screen appears with the choices Open Save Cancel?
    AMD Opteron 146 2.8ghz 280x10
    1GB GEIL ONE S PC3200
    DFI LanParty UT NF4 Ultra-D
    ATI X1800XT @ 700/800
    Enermax Noisetaker 485W
    BigWater SE
    Apr 2003
    Brownsburg, IN
    1,787
    This is why you should switch to Firefox: www.mozilla.org
    ska7ing away..... doddsy's Avatar
    Nov 2003
    a long way from home
    9,345
    i though this would be easy to find in tools --internet options, but i can't find it.
    but...............
    if you are using xp you might want to install sp2, its got a more secure approach to downloading.
    XP SP2 ignore all the stuff about installing on more than one machine, getting this full file is better IMO than auto update.
    might also try Firefox as an alternative.
    Warsaw, Poland
    6,444
    i do have SP2... and i dont want to install any other browers... last time i installed Mozilla i couldnt access my bankaccount...
    BigWater SE
    Father V2.0 washe's Avatar
    Feb 2002
    Mexicali, Mexico
    5,144
    If you have sp2 (winxp) installed then you have the most up to date version of IE..
    And when was the last time you tried other browsers... firefox is widely supported.
    someone is more skilled than you!
    http://s7.bitefight.org/c.php?uid=23753
    Warsaw, Poland
    6,444
    i only have the certificates for IE... so i cant use any other browser... isnt there anyway to fix that in the registry or sumthin?
    BigWater SE
    Retired mostly.
    Finland
    5,150
    Might work for your ie6, too.
    http://support.microsoft.com/?kbid=238723
    Member mpc's Avatar
    Dec 2001
    Bay Area
    395
    Go to control panel>Folder Options>File Types, select each type of file you want a confirmation dialog box for>click "Advanced">check the box that says "confirm open after download".
  1. HL2 wont load!
    By vikeor in forum General Gaming Discussion
    Last Post: November 17th, 2004, 11:56 AM
  2. Knoppix 3.3 is now out !
    By crouse in forum Applications and Operating Systems
    Last Post: September 24th, 2003, 05:52 PM
  3. Unable to load some sites with IE6
    By Spook01 in forum Applications and Operating Systems
    Last Post: February 22nd, 2003, 11:39 PM
  4. Internet Explorer 6
    By main in forum Technical Support
    Last Post: September 2nd, 2002, 07:29 PM
  5. IE6 upgrade error
    By mad1 in forum Applications and Operating Systems
    Last Post: March 18th, 2002, 04:47 PM
