Results 1 to 7 of 7
    Senior Member Front242's Avatar
    Aug 2003
    Montana
    531
    Fix "NTLDR missing" in XP (works for 2000 as well)
    This assumes that you have already checked your floppy for a non system disk.
    1. Start your computer with a Windows XP CD-ROM.
    2. At the Setup screen, press R for repair.
    3. Opt to use the Recovery Console (press c).
    4. Type 1, and then press Enter (if you have more than one windows install then choose the number of the install you want to repair).
    5. Type your Administrator password, (the one that you setup when you were installing the OS) and then press ENTER. If you do not know what it is try leaving it blank. If that does not work, find out what it is from the person that did the install.
    6. Type map, and press Enter. This should tell you the drive letters assigned to the drives and what type of drives they are. this is very useful if you have multiple drives. This is for reference only.
    7. Type: copy "drive":\i386\ntldr c:\ ("drive" will be the drive letter that corresponds to the CD-Rom Drive your XP CD is in. Refer to step 6.) Press Enter.
    Type: copy "drive":\i386\ntdetect.com c:\
    Type y If you are prompted to overwrite this file, then press Enter.
    8.You can do this to check your new boot ini file if you wish but this step can be skipped if you are confident that all is good.
    Type: type c:\Boot.ini
    You should see something like this:
    [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /fastdetect.
    Aug 2003
    Montana
    531
    bump
    Jan 2008
    2
    If copying from the XP disk, you have to expand the files. They are compressed, so simply copying them wont work.
    expand "drive":\i386\NTLDR "drive":\
    same with ntdetect.
    Banned Keymaker's Avatar
    Jan 2005
    Loveland, CO
    5,486
    Way old post dude.
    Jan 2008
    2
    Quote Originally Posted by Keymaker View Post
    Way old post dude.
    The thread is ages old, but the issue still stands
    Jan 2005
    Loveland, CO
    5,486
    Ya, but didn't he already give instructions on how to replace NTLDR?
    I mean ffs! http://support.microsoft.com/kb/318728
    There is all kinds of threads on this very topic too.
    Oh, welcome to Tech (noob)imo.
    Sep 2008
    Fix ntldr easier
    For someone who have not skils with cmd or recovery console here is another way.
    1)Copy ntldr ,command.com and boot.ini from another PC to flopy disc
    2)Insert flopy into PC
    3)Bott PC with ERD Commander or Badara boot cd(I recomended Badara.)
    4)Copy ntldr ,command.com and boot.ini from Flopy Disk to system drive (usualy C
    5)Restart PC and remove Boot CD
    Red Barron
    Write to me and correct something I told wrong
    rpralica@gmail.com
  1. NTLDR missing
    By techteen143 in forum Technical Support
    Last Post: June 2nd, 2007, 06:57 PM
  2. NTLDR Missing on Formatted HD???
    By Anglblueyes21 in forum Applications and Operating Systems
    Last Post: November 10th, 2004, 11:38 PM
  3. missing ntldr file - help xp home edition
    By hstorer721 in forum Technical Support
    Last Post: June 7th, 2004, 08:52 AM
  4. HELP: NTLDR Missing! (WinXP)
    By diabloroker in forum Technical Support
    Last Post: February 11th, 2004, 04:19 PM
  5. NTLDR and DISK I/O problem
    By OcLpRk8699 in forum Technical Support
    Last Post: August 14th, 2003, 07:49 PM
