Page 1 of 2 1 2 LastLast
Results 1 to 20 of 24
    Dec 2005
    Philadelphia
    98
    Freeware advice.
    Hello all, i just had to clean install xp on a friends computer because she destroyed it with porn, installing adware, malware, and lots of trojans and i couldnt clean it up because she ran it infected for so long it was embeded in everything.
    now i have xp pro sp2 with avast installed. any suggestions to help protect this thing would be great, i'd like to stick to freeware too. i know she isnt going to listen and stop browing the web. if i block script she wont be able to view some of her websites either.
    the stage is set, don't forget to breathe.cs
    Mar 2002
    Under Your Bed
    8,914
    For starters, browse with Firefox:
    http://www.mozilla.com/firefox/
    Free popup stopper:
    http://www.panicware.com/product_psfree.html
    Install some free common sense into her as well.
    Ultimate Member DanGrease's Avatar
    Aug 2003
    2,720
    - Ad-Aware
    - Spybot - S&D
    - SpywareBlaster (not a remover, a protector)
    - CCleaner
    Mar 2002
    Under Your Bed
    8,914
    I must be tired, because I forgot about CCleaner...he's referring to Crap Cleaner, a junk file remover. Always run it BEFORE you scan for malware as it saves you a lot of time and may delete those naughty files.
    www.ccleaner.com
    I also like CleanUp as it removes stuff that Crap Cleaner misses and vice versa.
    You can go to www.download.com to get the other apps that Dan mentioned.
    Ultimate Member radio1_mike's Avatar
    Weymouth, MA
    1,777
    Martoch-
    As a Pats fan, I wish your Steelers good luck!
    Also, does Cleanup really pick up junk CC misses?
    New Dad since 07/06/2005
    Mar 2002
    Under Your Bed
    8,914
    Yay, thanks!
    Sure...I'm not saying it picks up a TON of stuff that CCleaner misses. Go ahead and run CCleaner, then run CleanUp on the standard setting...you'll see what I mean (hopefully).
    Mar 2005
    England
    1,083
    try zonealarm firewall its my comprehensive then window ghey firewall, i swear the windows firewall dosnt even ask programs for access half the time, i dont want any m$ crap accessing the net without my knowledge. call me paranoid if you want.
    others pretty much covered the rest, def go with firefox its more secure.
    Senior Member buckaro's Avatar
    Dec 2005
    989
    CWSshredder is also quite a good program against malware. my advice would be to quit the downloading(i have... ).
    Firefox is good, there are other browsers which are good also, and i probably will change in the future when FF becomes to insecure(loads of people using it=security sucks...e.g. IE!)
    Weymouth, MA
    1,777
    Quote Originally Posted by Martoch
    Yay, thanks!
    Ok!
    Ultimate Member SeanC's Avatar
    Milton
    4,832
    If you can find a copy of the free version use Sygate firewall over Zonealarm. Their software is getting a little bloated and heavy too.
    Dec 2005
    989
    Sygate IS NOT FREE! Sure, you may get an old version of it, but you won't ever get updates for it...ZA is the best free firewall around now, you just can't beat it(although you may have compatibility issues, with avast i think there is, but i reckon is user related)
    Aug 2003
    Madison, WI
    15,220
    Aug 2003
    Madison, WI
    15,220
    Quote Originally Posted by buckaro
    Ah, how often does a firewall really need to be updated?
    Sygate is an awsome firewall...and the old version is free...
    USA
    127
    Sygate has hardly ever been updated anyways and it was one of the best then, why would now be any different?
  15. #15
    Dec 2005
    989
    Im sure i posted a response to this...
    What i say is, if updates aren't needed very often then how come Sygate couldn't carry on their free version? surely it would be easy enough and worthwhile enough to send out free updates also? Or apparently not...?
  16. #16
    Smile. It's easy. :) paul9's Avatar
    Aug 2003
    Gateshead U.K.
    14,175
    Because Sygate was bought by Symantec (Norton) who already have a range of "Internet Security Products" ( ) for sale. IIRC, Sygate's paid version of their firewall is being scrapped too, making way for Symantec's awful range of buggy, bloated, resource hogging software.
    Quote Originally Posted by Sygate's website
    Important Notice: Effective November 30th, 2005 all Sygate consumer firewall products will be discontinued. For technical assistance with these products, please email SMBSupport@Symantec.com. In addition, the consumer firewall support forum will be available for 60 days per our standard support policy. Note: this end of life only applies to the consumer firewall products and does not affect Sygate's Enterprise firewall and endpoint compliance products, which are still be updated and supported. Thank you and we look forward to assisting you with the wonderful line of Symantec products. Please click here for Symantec Support.
    If your Sygate Personal Firewall product is due for renewal, please visit Symantec's online store for special upgrade pricing on Norton products.
    If you did not previously own a Sygate Personal Firewall product, please click here to visit Symantec's online store.
  17. #17
    Ultimate Member elroy's Avatar
    Indiana
    3,774
    I'm running Microsoft Anti Spy on one machine. It seems to do a good job and from what I've read it gets pretty high ratings. It's a free download.
    Benjamin Franklin
  18. #18
    USA
    127
    Quote Originally Posted by paul9
    I don't use Windows anymore so I wasn't aware it was being dropped by Symantic also. I guess you can forget my previous reply and consider me one of the people who won't be suggesting Sygate anymore. Thanks for the info.
  19. #19
    Aug 2003
    Gateshead U.K.
    14,175
    I still use it. I changed after having a couple of software incompatability problems with Zone Alarm. You can still get it on a few download sites, and it works well.
  20. #20
    Aug 2003
    2,720
    Sygate was bought by Symantec? Well, that sucks. I use Zone Alarm at the moment though, works well.
  1. Freeware CD
    By Vyx in forum General Tech Discussion
    Last Post: August 17th, 2004, 02:26 AM
  2. Need Freeware Datebook
    By Tomteriffic in forum Applications and Operating Systems
    Last Post: February 6th, 2003, 05:56 PM
  3. freeware for tv with pc
    By alpha-kilo in forum PC Hardware
    Last Post: January 25th, 2003, 10:13 AM
  4. Best freeware PIM? and other freeware?
    By John Prophet in forum Applications and Operating Systems
    Last Post: November 21st, 2002, 04:16 PM
  5. Freeware?
    By Foggy in forum General Tech Discussion
    Last Post: April 9th, 2002, 10:17 AM
