Results 1 to 5 of 5
    Changing redirected My Documents folder location in SBS 2003
    Hi I am trying to figure out how to change the location from the default location on the c drive to move it to the d drive partition on on my SBS 2003 Server. I made
    the C drive partition small so that it would just be for applications and a D and E drive for files and exchange mail files. I also cant figure out how to move the exchange file to the E drive. Im assuming I need to do it through group policy, but I am not exactly sure how. Thanks
    Mar 2007
    My own little world.
    11,764
    You're right it is in a GP.
    In "Server Management" you should be able to go to the "Advanced" section (the lower half) and drill into that to get it.
    I did it on my first (now offline) W2k3 SBS, and as I haven't done it for a while, I can't remember exactly where it was - but I was able to find it as a partially-set-up wizard...
    I need to get myself off up to bed, I will have a look tomorrow..
    Mar 2007
    11,764
    I've found this (I had to use <F1> to bring up help, as I couldn't remember where I'd found to do it).
    My Documents Redirection:
    Folder redirection
    User settings and user files are normally stored in the local user profile, under the Documents and Settings folder. The files in local user profiles are only accessible from the current computer, which makes it difficult for users who use more then one computer to work with their data and synchronize settings between multiple computers. Two different technologies exist to address this problem: Roaming Profiles and Folder Redirection. Both these technologies have their advantages and they can be used separately or together to create a seamless user experience from one computer to another. They also provide additional options for administrators managing user data.
    Folder Redirection allows administrators to redirect the path of a folder to a new location. The location can be a folder on the local computer or a directory on a network file share. Users have the ability to work with documents on a server as if the documents were based on a local drive. The documents in the folder are available to the user from any computer on the network. Folder Redirection is located under Windows Settings in the console tree of the Group Policy Object Editor.
    Where?
    • <LI class=branch style="MARGIN-LEFT: 0em">Group Policy object name <LI class=branch style="MARGIN-LEFT: 0.75em">User Configuration <LI class=branch style="MARGIN-LEFT: 1.5em">Windows Settings
    • Folder redirection
    There are five folders that can be redirected:
    • My Documents
    • My Pictures (Redirection of My Pictures is provided for backward compatibility reasons, and not as a primary feature. You can only redirect the My Pictures folder using the Windows XP or Windows Server 2003 operating system if you are editing GPO that was originally created on Windows 2000 computer and that redirected My Pictures.)
    • Application Data
    • Desktop
    • Start Menu (Only for Terminal Server users.)
    Advantages of Folder Redirection
    • When roaming user profiles are used, only the network path to the folder is part of the roaming user profile, not the folder. Therefore, its contents do not have to be copied back and forth between the client computer and the server each time the user logs on or off, and the process of logging on or off can be much faster.
    • Even if a user logs on to various computers on the network, their documents are always available.
    • Offline File technology gives users access to the folder even when they are not connected to the network. This is particularly useful for people who use portable computers.
    • Data that is stored in a shared network folder can be backed up as part of routine system administration. This is safer because it requires no action on the part of the user.
    • As an administrator, you can use Group Policy to set disk quotas, limiting the amount of space that is taken up by users' special folders.
    • Data that is specific to a user can be redirected to a different hard disk on the user's local computer from the hard disk that holds the operating system files. This makes the user's data safer in case the operating system has to be reinstalled.
    • The Volume Shadowcopy Service feature of Windows Server 2003 can be used by users to recover older copies of the files in their redirected folders without intervention of technical support personnel.
    • Folder Redirection is a secure way to keep user data on a network, provided that the option Grant the user exclusive rights is turned on.
    Selecting a Folder Redirection target
    The Target tab of the folder's Properties dialog box allows the administrator to select the location of the redirected folder on a network or in local user profile. You can choose between Basic and Advanced settings. Basic redirection will be applied to all users affected by the GPO. The Advanced setting allows you to provide different redirection locations for users based on the users' security group membership. Using either advanced or basic redirection you can set different targets for folder redirection:
    • Create a folder for each user under the root path. This option will create a folder in the form \\server\share\User Account Name\Folder Name. Each user will get a unique path to their redirected folder. This option is not available for the Start Menu folder.
    • Redirect to the following location. This option will use an explicit path to the redirection location. This can cause multiple users to share the same path to the redirected folder.
    • Redirect to the local user profile location. This option will move the location of the folder to the local user profile under Documents and Settings.
    • The My Documents folder has one more option: Redirect to the user's home directory. To use this option, the administrator needs to use Active Directory Users and Computers to set the home directory attribute on the user objects for each user affected by the policy. Note
      • The Redirect to the user's home directory option causes the value of the Grant the user exclusive rights option on the settings tab to be ignored.
    Granting exclusive rights to special folders
    The Settings tab in the Properties dialog box contains a check box labeled Grant the user exclusive rights to My Documents. This option controls permissions on the newly-created redirected folder. If this option is selected, and the target directory doesn't yet exist, Folder Redirection will create the directory and set permissions on this directory to allow only the user and the local system full control over the folder. If this option is selected, and the target directory already exists, then Folder Redirection will verify ownership of the directory. If the directory is owned by someone else, Folder Redirection will fail. Whatever permissions are in effect by default remain in effect. If you clear this check box, no changes are made to the permissions on the folder. Whatever permissions are in effect by default remain in effect. The Start Menu folder can only be redirected with this option turned off.
    It is recommended to secure the contents of all folders except the Start Menu by selecting the Grant the user exclusive rights option on the Settings tab. The Start Menu folder is special in this respect, because redirection of the Start Menu is recommended to be used only for Terminal Server users, with all users sharing the same Start Menu folder. Therefore, the Start Menu folder doesn't have an option to select Grant the user exclusive rights.
    Policy removal considerations with regard to Folder Redirection
    The following table summarizes what happens to redirected folders and their contents when the Group Policy object no longer applies.
    Move the contents of the special folder to the new location settingPolicy Removal optionResults when policy is removedEnabledRedirect the folder back to the user profile location when policy is removed
    • The special folder returns to its user profile location.
    • The contents are copied, not moved, back to the user profile location.
    • The contents are not deleted from the redirected location.
    • The user continues to have access to the contents, but only on the local computer.
    DisabledRedirect the folder back to the user profile location when policy is removed
    • The contents are not copied or moved to the user profile location.
    Caution
    • If the contents of a folder are not copied to the user profile location, the user cannot see them.
    Either Enabled or DisabledLeave the folder in the new location when policy is removed
    • The special folder remains at its redirected location.
    • The contents remain at the redirected location.
    • The user continues to have access to the contents at the redirected folder.
    Important
    • Changing the redirection option to Not Configured does not redirect the folder to the local profile, this option means that Folder Redirection no longer controls the location of the folder-if a folder was previously redirected it will continue to be redirected to the previous location. If an administrator wanted to return the folder to the local user profile they should use the Redirect to the local user profile setting.
    Folder Redirection and Offline Files
    The Offline Files technology applies to any mounted or mapped drive that contains documents or data that a user might want to use offline. Offline Files does not depend on Folder Redirection. It is set up and configured on shared network servers separately from the Folder Redirection snap-in. Offline Files enables the user to do useful work even when not connected to the network, for example, on a portable computer or in the event of router failure.
    If you use redirected folders of any type, it is recommended that you set up Offline Files as described in the following table.
    Special FolderOffline File configurationMy DocumentsAutocaching for documents (or manual caching for documents, if you want users to have to manually make files and folders available for offline use) My PicturesAutocaching for documents (or manual caching for documents, if you want users to have to manually make files and folders available for offline use) Application DataAutocaching for programs DesktopAutocaching for programs if the desktop is Read Only Start MenuAutocaching for programs
    Folder Redirection permissions
    It is recommended to let Folder Redirection create folders for you. If you let Folder Redirection create folders for you, correct permissions are set automatically. Usually, knowledge of these permissions is not necessary. However, there are three reasons the permissions might be of interest:
    • An administrator must always secure the network file share used for keeping redirected folder data by setting correct share level (SMB) permissions and NTFS file system permissions.
    • Sometimes administrators create the redirected folders before Folder Redirection creates them. The directories created by administrators cannot be used together with the Grant the user exclusive rights option because Folder Redirection verifies ownership of the directories before allowing the folder to be redirected. The following table shows what permissions have to be set for Folder Redirection to work with the Grant the user exclusive rights option turned off.
    • Redirection of My Documents to the home directory provides more relaxed security than standard folder redirection. The following table shows what security is in effect in the standard case.
    • NTFS permissions required for the root folder
      User accountFolder Redirection defaultsMinimum permissions neededCreator OwnerFull Control, subfolders and files onlyFull Control, subfolders and files onlyAdministratorsNo permissionsNo permissionsEveryoneNo permissionsNo permissionsLocal SystemFull Control, this folder, subfolders, and filesFull Control, this folder, subfolders, and filesSecurity group of users who need to put data on the shared network serverN/AList Folder/Read Data, Create Folders/Append Data - This folder onlyShare-level (SMB) permissions required for the root folder
      User AccountFolder Redirection defaultsMinimum permissions neededEveryoneFull Control No permissions (Use security group)Security group of users who need to put data on the shared network serverN/AFull ControlNTFS permissions required for each user's redirected folder
      User accountFolder Redirection defaultsMinimum permissions neededUserNameFull Control, owner of folderFull Control, owner of folderLocal SystemFull ControlFull ControlAdministratorsNo permissionsNo permissionsEveryoneNo permissionsNo permissions
    OK thanks. I will take a look at this and see if has the info i need. I will let you know if I need anymore help .Thanks
    Mar 2007
    11,764
    No worries, it should be good to go - I was tempted to set it up, but I've already done that manually (only the three of us here, using three computers...) and I was able to get right up to the point of being able to push the GP...
  1. Changing default location of 'Documents and Settings' folder in XP
    By griobhta in forum Applications and Operating Systems
    Last Post: February 25th, 2010, 01:18 PM
  2. Changing Exchange folder location in SBS 2003
    By dlcallirgos in forum Applications and Operating Systems
    Last Post: February 26th, 2009, 12:23 AM
  3. Sbs 2003
    By bdj in forum Applications and Operating Systems
    Last Post: June 7th, 2006, 09:31 AM
  4. Moving location of documents and settings
    By ken_shoti in forum Applications and Operating Systems
    Last Post: December 27th, 2005, 10:16 AM
  5. Changing the location of shared documents
    By bigfeta in forum Applications and Operating Systems
    Last Post: July 18th, 2005, 12:40 AM
