Results 1 to 3 of 3
    Dallas, TX
    12,971
    AVG 2011 64-bit - update causing boot problem on Win 7
    Some Windows 7 Operating Systems Cannot Be Started After Latest Update
    Free Antivirus | Forum - Some Windows 7 Operating Systems Cannot Be Started After Latest Update
    "Common Sense is a flower that doesn't grow in everyone's garden."
    All We Are Asking Networker4321's Avatar
    May 2009
    The Farm
    6,808
    I had the same problem on XP Pro (SP3). I ending up removing each component and the problem went away. And this was on one of the bigger rigs I built. I also think it burned up a strip of good OZR 2GB memory. I have swapped slots and machines and memtest can't even SEE the card. Thank goodness it was a pretty rugged Gigabyte mobo.
    New Avatar? I like it. Back to the oncologist Wednesday, I am now 7 years out after beating pancreatic. Had the full Whipple procedure, was cut from stem to stern. They even took out a foot of duodenum. Ain't life grand?
    Three things cannot be long hidden: The Sun, The Moon and The Truth - Buddha
    Jan 2011
    Ireland-Europe
    6
    this also happened to a friend of mine weirdly tough he was running windows 7 32bit so im not sure if its the same issue he had vista on the computer before installing 7 all went fine till he installed AVG he done a restart then the computer gave an error ''this display is not supported'' weird i tough he brought it into pc world here in ireland and the said the computer was unfixable surely AVG could cause this much damage could it?everything was fine on the PC prior to the install of AVG
  1. Speed up Win 7 boot time a bit
    By batmeat in forum Applications and Operating Systems
    Last Post: November 7th, 2009, 05:04 PM
  2. Migrating Win 2003 32-bit to 2008 64-bit
    By MTAtech in forum Applications and Operating Systems
    Last Post: September 30th, 2009, 08:53 PM
  3. update AVG
    By cera in forum Technical Support
    Last Post: February 2nd, 2009, 09:05 AM
  4. AVG update
    Last Post: February 1st, 2009, 10:05 AM
  5. AVG Update Help
    By zrogoszinski in forum Technical Support
    Last Post: July 19th, 2008, 03:45 PM
