Results 1 to 3 of 3
    SM Bus Controller's driver critically required? PLEASE HELP!
    Hello,
    Is SM Bus Controller's driver a critical required driver? If it is, would it cause start up and shut down errors and other errors/malfunctions? I can't obtain the driver because I'm running XP on a Vista/7 machine. What does SM Bus Controller do anyways?
    Specs:
    Name- a6200n
    Made by- HP
    OS- windows xp 32-bit ( stock OS, windows vista 64-bit )
    CPU- AMD Athlon 64 x2 5000+ socket am2 @ 2.6 GHz
    HDD- 320GB Barracuda 7200.10
    Ram- 2gb
    someone please reply ASAP, I've been without a good computer for about a week!
    Thanks,
    ...Don't Mind Me... ShyguyXPC's Avatar
    USA
    19,338
    Problem with the Driver for SM Bus Controller (Windows) | HP® Support
    might have to find the exact chipset you have, and look for it over at the Nvidia website for the SM Bus Drivers for that chipset for Windows XP.
    Thx for the reply!
    I tried that link. But even if i go to ms, HP, nvidia and the mobs manufacture's website. Yet i found the driver for it but is only for windows 7 & vista. Also without the driver will it cause problems?
    Thx for the reply,
  1. VIA Bus Master IDE Controller Driver Problem
    By AQR8 in forum PC Hardware
    Last Post: March 14th, 2006, 10:19 PM
  2. SM BUS CONTROLLER
    By nissan1998 in forum Applications and Operating Systems
    Last Post: January 22nd, 2006, 03:36 PM
  3. Replies: 12
    Last Post: September 2nd, 2003, 10:01 AM
  4. SM BUS Controller
    By Mister_L in forum Technical Support
    Last Post: September 2nd, 2003, 09:59 AM
  5. Fan bus speed controller?
    By Bizkitkid2001 in forum General Tech Discussion
    Last Post: April 22nd, 2003, 09:27 PM
