Results 1 to 3 of 3
    Ultimate Member TOAD6147's Avatar
    5,487
    Help please with Ubuntu 15.10 disk space issue
    I've been trying to run the software updater but I keep getting the following (paraphrased) error message:
    "There is not enough disk space on "/boot". Free up at lease 32.5 MB (download size is 67.1 MB) on this disk, Empty trash (done) and remove temp packages of former installs using "sudo apt-get clean" (done although I get no confirmation that the task completed)."
    After following those instructions I still get the same error. This makes no sense because according to the Disk utility my Block device of 496 GB reports that there is 482 GB free. If there is a way to export a log to upload please advise or I can provide the partition details if needed. Thanks in advance for your assistance.
    foolish their lack of understanding."
    Ambrose Bierce
    Apr 2016
    New York
    19
    I had the same issue a few weeks ago. My solution was to delete unneeded kernels. I had ~8 installed at the time. I kept 4, but it gave me more than enough space.
    Safely Remove / Delete Old Linux Kernel from a Linux Server
    5,487
    After reading many suggested solutions the one that worked for me was running 'apt-get remove'.
    Ambrose Bierce
  1. Hard Drive/Disk Space Issue
    By TPWalton in forum Technical Support
    Last Post: August 12th, 2009, 09:52 AM
  2. Weird Disk Space Issue on T42 laptop
    By pos_user in forum General Tech Discussion
    Last Post: December 23rd, 2008, 10:50 AM
  3. GRUB, Ubuntu and Win XP issue
    By daveleau in forum Applications and Operating Systems
    Last Post: September 1st, 2008, 11:55 PM
  4. Ubuntu server issue
    By Thread_Necro in forum Applications and Operating Systems
    Last Post: September 25th, 2006, 12:39 PM
