Results 1 to 11 of 11
    Senior Member ablang's Avatar
    Sacramento, CA
    927
    Convert NTFS drive to FAT32 in DOS?
    Stupid Windows 2000 Pro. I came to the option (from the 4 boot disks) to install it on FAT32 or NTFS, but it refused to install on FAT32, so I went w/ NTFS and it wouldn't install on that either. So now I can't get my drive back. Can I Convert NTFS drive to FAT32 in DOS?
    Senior Member mike_sanfil's Avatar
    Sep 2003
    986
    i don't think you can, you would have to move the data off the drive and then reformat.
    Senior Member bailey's Avatar
    Oct 2003
    port hope, michigan
    800
    correct
    you can't go from ntfs to fat32
    save what you want and remove the partition and create a new one.
    nuisance since 1968 OuTpaTienT's Avatar
    ɐqɟs
    10,458
    Partition Magic will do it. But other than using that or a similar utility, no, it can't be done without a reformat.
    10,821
    well u said it wouldnt install..so I guess you dont have any data to save.
    you can just boot to a Win98se or WinME type floppy and run fdisk and do "remove non-dos partition" and then you can start from scratch
    275
    how can i format Fat32 from NTFS ??
    what should i do ..
    i couldn't get it back to Fat32 in WinXP ...
    now i have two hards ... one in Fat32 with XP Pro ... and one new formatted as a NTFS .. now i wanna get the new one back to Fat32... what can i do ?
    Nov 2004
    21
    Dude it has already been mention from the previous post you can't once you converted FAT32 to NTFS there no turning back the only way to do is to format your hard drive.
    275
    yes yes ~ i knew i have to format my hard drive ...
    but how to format my hard drive ???
    using the winXP CD to format it ???
    Banned
    Nov 2004
    19
    Exclamation rtfm
    Quote Originally Posted by rex028
    You have a Windows installed system,right ?
    Now you see why i don't.
    So 1.Are you booting to Windows now ?
    2.Why have you got to this point ?
    3.Put in floppy disk 1 and learn Dos commands like
    fdisk then type enter.Then format.But it will probably be NTF.
    Who can add to this ?
    Nov 2004
    21
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    spammer gone
    Hard Sayin Not Knowin
