May 10th, 2004, 11:17 AM #1Junior Member
- Apr 2004
- Location
- AR
- 7
compaq with xp changes from 32bit to 8bit every boot
i am working on a junky old compaq that has an xp upgrade on it, it will run 32bit fine but after every time it is booted it comes up in 32bit then flashes and changes itself to 8 bit, this machine is on the edge of being too slow for xp and only has 128meg ram with 8 of it shared for the video, i went thru msconfig and turned alot of stuff off i am installing windows updates at the moment, any help
May 10th, 2004, 11:50 AM #2Ultimate Member
- Oct 2001
- 10,821
try going to www.blackviper.com
check out his "xp services configurations"
basically he is showing that xp has a lot of junk running that u dont need running....I am thinking you can free up like 30mb of ram use by turning the junk off....
There r different columns..I use pretty much the "safe" column execpt I leave "system restore" enabled
some of the junk that can be disabled is
Alerter
Backbround Intelligent transfer service
clipbook
computer browser
etc etc
also you can turn off a lot of the visual "eye candy" that uses resources by right clicking "my computer"....click "properties"...."advanced"....beside "performace" click "settings"----then under "visual effects" uncheck most of that stuff....that will free up some memeory/resources etc."Even a fool is thought to be wise if he is silent"
difference between 16bit and 32bit os's
By iseeu_3 in forum Applications and Operating SystemsReplies: 7Last Post: November 23rd, 2003, 11:39 AM -
Why "Newbee"..?
By 8bit-freak in forum IMO CommunityReplies: 18Last Post: February 10th, 2003, 07:22 AM -
Need help with Compaq Presario 700 Notebook PLEASE!!
By impostercity in forum Mobile ComputingReplies: 13Last Post: November 30th, 2002, 04:11 PM -
Mixing RAM...
By mAdMaLuDaWg in forum General Tech DiscussionReplies: 15Last Post: October 23rd, 2002, 08:43 PM -
Which budget graphics card for this system?
By JayMan in forum Graphics Cards and DisplaysReplies: 26Last Post: April 30th, 2002, 03:39 AM
If you failed to see the political statement in both ,then you see what you like to see
The FBI has killed another person...
