Thread: Help with jo.sys
June 10th, 2004, 09:24 AM #1Junior Member
- Jun 2004
- 2
Help with jo.sys
Hope someone can help! With the default jo.sys the default is to boot to the hard drive. What I want to do is switch them around so the booted media (cd,dvd) is selected. I downloaded Bart's freejo.exe but cannot figure out how to make the switch. There is a reference to using the timeframe value but no instructions on how to use it.
June 10th, 2004, 09:47 AM #2Ultimate Member
- Oct 2001
- 10,821
Welcome to the forum!
I am not familiar with jo.exe or what you are trying to do..but I did check out the instruction page http://www.nu2.nu/jo/
are you trying to make a special boot floppy?
or just trying to get menu options at the regular bootup?
did you see this?---> "Unzip the files from the download zip file into some directory on your harddisk. Start "freejo.exe" to configure jo.sys behaviour. Then copy the jo.sys file onto a Windows 98 or ME boot diskette and your done.
No need to add anything to your config.sys (like some users seem to think...)"
so evidently you arent actually using the "freejo" to run...you are only using it to configure the jo.exe file which is then what you run....
JP"Even a fool is thought to be wise if he is silent"
June 10th, 2004, 12:16 PM #3Junior Member
- Jun 2004
- 2
I've got freejo.exe running correctly and placing the newly created jo.sys correctly. The problem (or inconvienence) is that at startup jo.sys asks if you would like to startup to the hard disk or the media booted from. Default is hard disk, I would like the booted media to be default.
What I am doing is creating a bootable dvd (using easyboot) with a ghost image on it. Hope that clarifies the problem. If anyone has a better option I'm open to suggestions.
Thanx again.
February 5th, 2005, 01:22 PM #4Junior Member
- Feb 2005
- 2
download the file Hedit.exe. open your jo.sys file and just below where it says time remaining you will see a 1. click on it and change to 2. save. now your cd will boot to the cd. ignore the highlighting of hard drive it highlights option 1 by default but will boot from 2.
February 5th, 2005, 01:42 PM #5
Changing Win 98 Startup screen
By Blazer06 in forum General Tech DiscussionReplies: 16Last Post: April 2nd, 2003, 08:39 PM -
PC won't boot...
By crazyray in forum Technical SupportReplies: 12Last Post: October 13th, 2002, 12:50 PM -
Himem.sys is missing
By Ebisoba in forum Technical SupportReplies: 28Last Post: March 8th, 2002, 12:13 PM -
WinXP Pro, config
By Doot in forum Applications and Operating SystemsReplies: 5Last Post: February 9th, 2002, 06:22 PM -
HELP!!! Windows doesn't boot up
By lost-and-found in forum Applications and Operating SystemsReplies: 10Last Post: January 3rd, 2002, 09:59 AM
Hello friends.. You have to watch all following movies at this sunday. Watch The Internship Online Watch The Kings of Summer Online Watch The East Online Watch Now You See Me Online Watch Fill...
enjoy online movies
