WMP 9 Color Problems
Currently Active Users: 2598
Discussions: 200,999, Posts: 2,380,005, Members: 246,368
Old June 24th, 2004, 11:20 AM   Digg it!   #1 (permalink)
Send a message via AIM to Slayertime Send a message via MSN to Slayertime Send a message via Yahoo to Slayertime
I just recently noticed that when i play movie down in my WMP 9 they are not in normal colors but in Hot Pinks Blues and Oranges. Sound is still there and its fine. Just the image is all messed up. Its wierd i tried to get a picture of it to show you but that doesn't work. Never had that happen before when i take the picture it comes out all black. I rolled back my video card driver thinking that was it nothin. Anyother solutions. I reinstalled WMP 9. Nothin still It only does this in WM( Real Player works fine and also Quicktime. If even does it when i stream from the internet.
Got a picture of it here is what is looks like
Sorry for the quality had to use m MiniDV cam to take it since print screen didn't work.
AMD Athlon 64 FX-53
Asus SK8V Mobo
120 gig HD
160 Gig HD
1024 gig Corsair XMS Extreme Edition Low Latency
Vision Tek ATI X800XT PE
Audigy 2 ZS
Slayertime is offline   Reply With Quote
Old June 24th, 2004, 11:29 AM     #2 (permalink)
FatalException's Avatar
I would suggest codec corruption if you hadn't said Quicktime and Real worked to play the same file properly. Try reinstalling the codec used to view the file you are playing back. If it's a divx file, download the latest divx codec from www.divx.com. It may be xvid too, in which case search for "xvid download" on google to get the latest binary install of that.
If it's straight from a DVD, then it might be time to reinstall your DVD playing software... Media player is just a cutesy frontend for all your codecs and media... it actually uses a lot of software that isn't MS related just to do simple things like DVD playback - hence the reason reinstalling DVD software will fix Windows Media Player's DVD playback too.
FatalException is offline   Reply With Quote
Old June 24th, 2004, 11:50 AM     #3 (permalink)
I reinstalled my divx and that worked fine thats man.
mp3 not playing! rhetoricsdead Multimedia and Audio 9 June 23rd, 2004 08:49 PM
Logitech Z-680's invertedflight Multimedia and Audio 26 July 22nd, 2003 02:03 AM
Can't open MP3's iNeb Applications and Operating Systems 33 April 6th, 2003 09:59 PM
Happy Birthday Surreal!! hawkeye177 IMO Community 48 July 25th, 2002 06:11 AM
Please welcome Surreal... ScottW IMO Community 89 February 5th, 2002 08:02 PM
Is It Just Me? (3111)
‘Rogue’ or ‘Rouge’? (9)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Laptop with wireless problem. (13)
[F@H SPAM 11/16/09] ! 1/2 months to.. (41)
add ram to existing (4)
Delete an OS (18)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (41)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
