LCD monitor
Currently Active Users: 1533
Discussions: 200,925, Posts: 2,379,128, Members: 246,291
Old July 30th, 2004, 11:07 AM   Digg it!   #1 (permalink)
LCD monitor
I would like to purchase a 17" lcd monitor but I would like to hang it upside down. I have a computer desk that has a top shelf and I would like t o attach it to the bottom of the shelf. Can I do this with this monitor. It would then clear my whole desk for work.
Seammark2
seanmark2 is offline   Reply With Quote
Old July 30th, 2004, 11:13 AM     #2 (permalink)
(AKA) Nakamura
sweeper2's Avatar
wouldn't your picture show up upside down..?
Old July 30th, 2004, 11:14 AM     #3 (permalink)
Father V2.0
washe's Avatar
Send a message via MSN to washe
some videocard let you rotate the image? dont?
someone is more skilled than you!
http://s7.bitefight.org/c.php?uid=23753
washe is offline   Reply With Quote
Old July 30th, 2004, 11:15 AM     #4 (permalink)
hokie64's Avatar
you COULD just find a way to suspend it from the top of the shelf. It'll take you a while and you'd have to be careful finding contact points on the back of the monitor. But with some steel wire, you could make a sweet looking setup, and wouldn't even have to turn it upside down.
hokie64 is offline   Reply With Quote
Old July 30th, 2004, 11:17 AM     #5 (permalink)
(AKA) Nakamura
sweeper2's Avatar
i think you can, bout how is that on the monitor though...could it damage it hanging it upside down...?
Old July 30th, 2004, 11:25 AM     #6 (permalink)
LCD monitor
Thanks for the replies. The easy way would be for me to stand on my head to look at it but that becomes very uncomfortable after a while. I guess I will have to use it the way it was meant to be even tho I have to sacrifice some space.
Seanmark
Old July 30th, 2004, 11:36 AM     #7 (permalink)
the *Voice* in your Head
PresterJohn's Avatar
if your lcd is vesa fdmi compliant you should be able to remove the mounting bracket/stand and substitute your own. you can buy prefabricated ones from a number of vendors or if you want to save some money and don't mind having a less polished look, you could probably jury-rig your own using acouple of L brackets and two strips of metal.
Hot Dell Dimension LCD deal John Prophet ResellerRatings Homepage Deals 7 April 21st, 2004 11:14 AM
Display Dilemma vesther Graphics Cards and Displays 4 March 21st, 2004 10:53 AM
incredible slowdowns stefdesh Graphics Cards and Displays 4 September 10th, 2003 02:03 AM
looking for a decent 17" or 18" LCD display Sixpac_XP Graphics Cards and Displays 1 April 4th, 2003 11:04 AM
Is It Just Me? (2865)
Obama the Muslim (14)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
