Thread: Operating System Help
August 16th, 2004, 05:40 PM #1
Ok well i installed the operating system win xp pro, and the thing is everytime i boot up i take all long time at the detecting the drives for it to boot and it wont boot into windows unless the windows xp cd is in there how do i fix this? I really need help
WD 80Gb IDE
Shuttle AN35-Ultra
thats some info, i need help
August 16th, 2004, 05:42 PM #2
Its the harddrive detected correctly in the bios?
August 16th, 2004, 05:43 PM #3
ya i think so how do i check that?
August 16th, 2004, 05:46 PM #4
most of the time its with the del key.
When you turn the computer look for x = Bios where x is the keyboard key to activate the function.
then check under your devices, also verify your boot order chances are that hd is not in the boot order so I wont use it to boot.
People usually use CD-ROM or, IDE-0
August 16th, 2004, 05:50 PM #5
August 16th, 2004, 06:00 PM #6
the drive was empty when you installed winxp?
did you got any errors during install?
August 16th, 2004, 06:14 PM #7
August 16th, 2004, 06:19 PM #8
and yes the hard drive was empty, ive reinstalled but it still does it ive also done fixmbr and fixboot
August 16th, 2004, 06:33 PM #9Ultimate Member
- Oct 2001
- 10,821
how is the drive set up on the cable? is it by itself on the cable?
if it is by itself then it should be set to "master" on the jumper...(unless it is Western Dig drive then it should be set to "single" I think)
check the jumper.
also..if you leave the bios set for "auto" and ther eis no drive there..then it make sit take all day cuz it tries to detect a non existent drive.....for instance if you have the main hard drive on the cable by itself...then in th ebios the Primary master should be set to 'auto" but the Primary Slave should be set to "none"....if u set the primary slave to 'auto" also it may make it boot really slow and/or give you an error since you have no drive there.....same for the Secondary controller etc"Even a fool is thought to be wise if he is silent"
August 16th, 2004, 06:36 PM #10
its by itself on the cable, and when it dectects the ide drives it says like Primary WD800BB something
August 16th, 2004, 07:01 PM #11Ultimate Member
- Oct 2001
- 10,821
in the bios then the primary slave should be set to "none"
August 16th, 2004, 07:08 PM #12
oh where do i fix that in the bios under like advanced options or wut?
August 16th, 2004, 07:26 PM #13Ultimate Member
- Oct 2001
- 10,821
no, under "standard cmos"
August 16th, 2004, 07:29 PM #14
change partition size in dual boot
By stevemu in forum Applications and Operating SystemsReplies: 2Last Post: July 19th, 2004, 05:00 PM -
Future of Operating Systems
By computerwizz in forum General Tech DiscussionReplies: 18Last Post: July 1st, 2004, 11:15 PM -
2 operating systems (but not really)?
By Pollo-Diablo in forum Technical SupportReplies: 2Last Post: December 9th, 2003, 11:18 PM -
best gaming os?
By iseeu_3 in forum Applications and Operating SystemsReplies: 16Last Post: November 5th, 2003, 06:11 PM -
hooking bootstrap, etc
By gadluk in forum Technical SupportReplies: 13Last Post: June 27th, 2003, 01:36 PM
I had a blood test once. I failed so they kicked me out of the hospital.
