problems when shutdown in linux
Currently Active Users: 1597
Discussions: 200,505, Posts: 2,374,392, Members: 245,829
Old February 2nd, 2002, 08:41 PM   Digg it!   #1 (permalink)
meanguy21's Avatar
hello guys, this has been really annoying " why i always have some weird problems "
well, i used to have debian with 2.4.12 kernel, when i used to shut the machine down using "shutdown -h now" ... the power turns off automatically, but then i had to get 40 gb hardisk, so i had to get a newier kernel, i tried 2.4.17 16 and 14 ... large hardisks are supported in those, but my pc doesn't power off like it used to! ... i asked around, and kept reading, no one knows, .... some told me to enable apm in the kernel, i did that, i enabled also "enable real calls power off " something like that, .... the module is successfully loaded, but still doesn't power off, i also checked if apm is enabled in the bios, and it is, turned it off, and back on again.... i tried everything i could
some ideas would really help =)
thanx
meanguy21 is offline   Reply With Quote
Old February 2nd, 2002, 09:19 PM     #2 (permalink)
Germ's Avatar
Send a message via AIM to Germ Send a message via Yahoo to Germ
Hi meanguy,
You need to put the -p flag in your shutdown script. I'm not sure where it is in debian, probably /etc/init.d/halt or /etc/rc.d/init.d/halt. Should look something like HALTARGS="-i -d -p"
HTH
Germ
How do you set this laser printer to stun??
Germ is offline   Reply With Quote
Old February 2nd, 2002, 09:41 PM     #3 (permalink)
meanguy21's Avatar
#! /bin/sh
# halt Execute the halt command.
# Version: @(#)halt 2.84-2 07-Jan-2002 miquels@cistron.nl
PATH=/sbin:/bin:/usr/sbin:/usr/bin
# See if we need to cut the power.
if [ -x /etc/init.d/ups-monitor ]
then
/etc/init.d/ups-monitor poweroff
fi
# Don't shut down drives if we're using RAID.
hddown="-h"
if grep -qs '^md.*active' /proc/mdstat
then
hddown=""
fi
halt -d -f -i -p $hddown
: exit 0
well, thats my halt script .... if i'm not mistaken it's already there.. right?
thanx! =)
Old February 2nd, 2002, 10:35 PM     #4 (permalink)
pbharris's Avatar
Send a message via ICQ to pbharris Send a message via AIM to pbharris Send a message via Yahoo to pbharris
hi menaguy - i assume you are compiling your won kernel and you have attempted to put in APM (power managemnt stuff).
Here are the options you need in to compile in:
Code:
# General setup
CONFIG_NET=y
CONFIG_PCI=y
# CONFIG_PCI_GOBIOS is not set
# CONFIG_PCI_GODIRECT is not set
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_PCI_NAMES=y
# CONFIG_EISA is not set
# CONFIG_MCA is not set
CONFIG_HOTPLUG=y
# PCMCIA/CardBus support
# CONFIG_PCMCIA is not set
CONFIG_SYSVIPC=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_SYSCTL=y
CONFIG_KCORE_ELF=y
# CONFIG_KCORE_AOUT is not set
CONFIG_BINFMT_AOUT=y
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_MISC=y
CONFIG_PM=y
# CONFIG_ACPI is not set
CONFIG_APM=y
# CONFIG_APM_IGNORE_USER_SUSPEND is not set
CONFIG_APM_DO_ENABLE=y
CONFIG_APM_CPU_IDLE=y
# CONFIG_APM_DISPLAY_BLANK is not set
CONFIG_APM_RTC_IS_GMT=y
CONFIG_APM_ALLOW_INTS=y
# CONFIG_APM_REAL_MODE_POWER_OFF is not set
if you need anymore help let us know
niceguy2
Odds are very good there are several spelling mistakes in this post.
pbharris is offline   Reply With Quote
Old February 2nd, 2002, 10:59 PM     #5 (permalink)
meanguy21's Avatar
thanx i'll try that, but where is the kernel config file?. ..
usually i use make xconfig over here, but i read the options, and i change my settings and made them like yours
btw, do u know how to set the hardware clock? since it's the one which usually appearns in the clock display?... is it a problem to change it from gmt to local time?
heh! i know u're a nice guy ... lol i bet u are :P~
Old February 2nd, 2002, 11:25 PM     #6 (permalink)
meanguy21's Avatar
back, i tried it , and it didn't work,
some ppl said the same about it....
like power off stopped when they upgraded to 2.4.14 + kernels ,.....
Old February 2nd, 2002, 11:34 PM     #7 (permalink)
pbharris's Avatar
Hello,
the kernel config file is generated when you od teh make xconfig - you have the option to save configuration to file - this is the file you can edit and then load configuration from file or under General setup have it look like this pic attached.
for the clock i go into the bios and set it to GMT then in linux i use timetool or timeconfig to apply my offset (in Chicago that is 6 hours i think...)
hth
Old February 2nd, 2002, 11:53 PM     #8 (permalink)
meanguy21's Avatar
hey budd, thanx! ... well thats what i did =) i saved the options, and got it compiled. gone all the way, rebooted, and tried the shutdown command, except i have the apm enabled as module ... then i loaded the module is modconfig ...... cuz it doesn't work when i tried checking Y for the apm to be a part of the kernel, thats when i checked the kernel's log, u can ask me to show u some logs if thats gonna help..
heheh about the time, i think i'll try that later ...
.... lets say i want it to show me the time which is 7 am... "man i should stop staying up before college starts again"
....... thats why no one knows whats wrong .. i even downloaded a new kernel, i tried the one in debian source and the one in kernel.org
suppose its my hardware? but if so, it wouldn't be working in 2.4.12 ;/
Old February 3rd, 2002, 01:00 AM     #9 (permalink)
pbharris's Avatar
i doubt there is any hardware problem.
it is giving the wrng time - you don't need to have it set to hardware time.
Old February 3rd, 2002, 01:14 AM     #10 (permalink)
meanguy21's Avatar
"nods" ..... so what u think? .... about the time also? what do u think i should do? i used ntpdate to snyc my time with any other server in my area, didn't work ;/
Is It Just Me? (1635)
Review My Build (5)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
Mic won't work. (2)
