Outlook 2003-- HELP!!
Currently Active Users: 2396
Discussions: 200,942, Posts: 2,379,328, Members: 246,305
Old September 16th, 2004, 10:35 AM   Digg it!   #1 (permalink)
discaman is offline   Reply With Quote
Old September 16th, 2004, 11:08 AM     #2 (permalink)
Under tools, select Rules wizard and create rules. You first create the folders you want under the inbox for each specific pop account. Then in rules wizard, you specify the criteria for the incoming emails and what actions Outlook should take for new emails coming in. You can also select emails when they come in and right click on them and select 'organize' - then tell outlook how you would like that specific email and all emails from that point onward to do.
pneuman76 is offline   Reply With Quote
Old September 16th, 2004, 01:01 PM     #3 (permalink)
Did you try Google yet?
Siliconjunkie's Avatar
Send a message via AIM to Siliconjunkie
Or use profiles. That would keep them completely seperate.
Siliconjunkie is offline   Reply With Quote
Old September 17th, 2004, 09:52 AM     #4 (permalink)
Old September 17th, 2004, 09:55 AM     #5 (permalink)
Are you using Outlook or Outlook Express?
Old September 17th, 2004, 09:03 PM     #6 (permalink)
Outlook 2003 Professional
Old September 17th, 2004, 09:21 PM     #7 (permalink)
Ok, when you have Outlook open, hit "F1" then search for orginize.
It is there, you are either not doing what was suggested, or not seeing it.
Old September 19th, 2004, 06:59 PM     #8 (permalink)
Old September 19th, 2004, 09:50 PM     #9 (permalink)
My guess would be that nobody is sending mail to it.
Old September 20th, 2004, 09:32 AM     #10 (permalink)
Outlook 2002 Archive.pst file getting too big osprey4 Applications and Operating Systems 18 August 24th, 2004 03:23 PM
Outlook Express 2003 Problem RipSH Applications and Operating Systems 4 December 13th, 2003 11:24 PM
Need Outlook 2003 addon: sort emails in special folders? gicio Technical Support 0 November 9th, 2003 05:16 PM
What's the best e-maill client? sulusulu Applications and Operating Systems 24 August 30th, 2003 07:32 PM
NAV 2003 problem alondra Applications and Operating Systems 3 March 5th, 2003 09:53 PM
Making Health Care Worse (157)
The disrespect of Obama by Russian .. (14)
Is It Just Me? (2918)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
