Results 1 to 16 of 16
    Senior Member fakan's Avatar
    Apr 2004
    California & Canada
    644
    Exclamation flash my hardrive
    I got 120GB hardrive maxtor - in external case connected to my laptop through USB.
    For some reason it started to show that its only 13GB drive.
    I'm trying to flash my hardrive bios .... should I use Max-Blast or is there something else ?
    Where I can get it ?
    Fur ballin Sixpac_XP's Avatar
    Victoria, BC
    4,371
    How old is the laptop..it may not recognize the hard drive size properly.
    Apr 2004
    California & Canada
    644
    laptop
    its 3.06GHZ dell brand new laptop ....
    I have tried to connect the drive to a different computer ( tower) and it recognized same size
    what should I use to flash the drive ? flashing the hardrive helps to gain back maybe few gigs but isnt it too hardcore when 120GB is showing only 13GB ?
    Apr 2004
    California & Canada
    644
    it was working fine for hmm 6 months maybe the laptop recognized the drive with out any problem .... after that I had some problems I had to format my laptop n stuff ... since than its showin only 13GB ....
    Victoria, BC
    4,371
    whats the model number of the USB drive and which OS are you using on your laptop?
    Apr 2004
    California & Canada
    644
    USB 2 and I'm using winXP PRO SP2 hmm is it going to be a problem to flash it ?
    Not sure if the fact that its connected through the USB won't cause any trouble
    Victoria, BC
    4,371
    Well if worked before it shouldn't be a problem with the drive. I would avoid flashing it.. I will look on Maxtor's site and see what I can find for you.
    Victoria, BC
    4,371
    I need the exact model number for the drive.. should be listed on the bottom of it.
    Apr 2004
    California & Canada
    644
    the drive is in the external case and the case is screwd with 15 bolts hmm is it necessery that number ? If its needed I can open it up it will just take a few minutes .......
    what else can I do if not flashing it ?
    the drive works fine only problem is its showing 13GB instead of 120 GB lool little detail
    Victoria, BC
    4,371
    OH... is a aftermarket USB hard drive enclosure because Maxtor makes there own USB external hard drives in their own enclosures.
    Apr 2004
    California & Canada
    644
    yeah its after-market external case that you buy for 40$ and than u just put in regular hardrive out of ur tower ... this way its much more cheaper ... instead of paying 350 - 400$ you just pay 150 already with the case or somethin like that
    should I take it out of the case ?
    Apr 2004
    California & Canada
    644
    max-blast
    what about flashing the drive ? how else can I get back the original size of the hd ?
    could I use max-blast ? I was looking for that little utillity on maxtor website but there is nothin like that
    Uncommon Man samwichse's Avatar
    State College, PA
    4,279
    Er, have you checked its partition table with a partition manager of some sort?
    You'll probably have to do this from within windows as DOS doesn't work too well with USB stuff (so no booting to a ranish partition manager disk). You might be able to use ranish from a command window though.
    Sam
    Apr 2004
    California & Canada
    644
    check for errors ? I use partition magic is that what you mean ?
    hmm thats what I think as well that connecting the hardrive through USB hm I dont even think that it would show up in dos mode
  15. #15
    State College, PA
    4,279
    Well partition magic works from windows, so what does it say?
  16. #16
    Apr 2004
    California & Canada
    644
    partition magic
    Ok this is very weird
    When I connect the hardrive to my laptop through USB and I try to run partition magic 8. it just display that error 100 " partition table is bad" and than shots down automaticly
    when I disconnect the USB drive the partition magic starts no problem and works like a charm...
    I had some stuff saved since I lost 120GB to 13GB I have saved some files there and now I'm trying to transfer those files back to my laptop .... but after 2-3 minutes of transfering it says that I/O error connection or cable error.
    but I can explore the drive and get little files out of there no problem
    any ideas ?
What is the color of the sky?
  1. Question in regards to KeyCodes
    By HuntinGalnMO in forum Security and Privacy Issues
    Last Post: October 9th, 2004, 02:33 PM
  2. resize my drive
    By fakan in forum Applications and Operating Systems
    Last Post: September 24th, 2004, 07:55 PM
  3. GB wont register?
    By cyclebreakers1 in forum PC Modification
    Last Post: August 1st, 2004, 06:02 AM
  4. FS: TI-83+, laptop, proc, bad mobos, etc.
    By emcron in forum Traders Forum: Buy, Sell, Trade
    Last Post: March 30th, 2004, 10:47 PM
  5. Mount hdd to a fan?
    By OC Guy in forum PC Modification
    Last Post: January 13th, 2002, 06:38 AM
