October 6th, 2004, 06:10 PM #1Junior Member
- Oct 2004
- 6
XP won't load after replacing HDD
Compaq Armada M700
XP home
18 months ago I bought a secondhand Armada and upgraded it from W98 to XP home with an upgrade disk.
The HDD has now failed and I bought a replacement drive.
I started the computer with the XP upgrade disk and it loaded some drivers etc and then there was a screen with 3 options. Load XP or restore system or quit. I tried R for restore and got a message to type EXIT. It then repeated the same operation. I did it once more but it now spins the DVD but there is no screen input at all. I tried replacing the XP disk for a restore Win 98 disk but get the same.
I tried putting the old drive in, that some times worked, but get the same result.
I am just a computer user and the Compaq is a computer my wife uses to surf and is also used for navigation software on the boat.
Can anyone advise me what steps to take to get the computer running again.
October 6th, 2004, 06:13 PM #2
You will need to install, not restore, if it is a new HD.
October 6th, 2004, 06:21 PM #3Junior Member
- Oct 2004
- 6
How dod I get back to the install screen. I was going to try that next. Also can I install with an upgrade disk?
October 6th, 2004, 06:27 PM #4
And also an upgrade Xp will need another OS to load.am I right?
October 6th, 2004, 06:36 PM #5Junior Member
- Oct 2004
- 6
Is there a limit on how many times I can run the upgrade disk? Is this the reason that I now get no screen input or is there another reason?
October 6th, 2004, 06:41 PM #6
you can probably put in the old drive, set the jumpers to slave, and master on the new one, then point the intall routine to that as the qualifying product, otherwise you will need a qualifying product cd for xp to check during the install.
the upgrade xp only needs another os to prove it is an upgrade and not just somebody trying to do a full version install on the cheap. the install itself is no different to a full version, just a licensing and price difference.
October 6th, 2004, 06:42 PM #7
no limits. what exactly do you mean by no screen input?
October 6th, 2004, 06:46 PM #8Junior Member
- Oct 2004
- 6
When I switch the computer on now, there is nothing on the screen, it is just blank. The computer LEDs light up and the DVD drive spins but then stops with no LED on the HDD. The fan is also rotating, otherwise nothing.
October 6th, 2004, 06:58 PM #9Junior Member
- Oct 2004
- 6
The computer is a notebook so I can only put in one drive and there is no option for slave or master. If I can get the computer back to loading the hard disk and giving me the 3 options, I would go to install but how can I get it there?
October 6th, 2004, 07:02 PM #10
try booting, then switch off the monitor power, then back on, sometimes this can bring your screen back into the real world. also, when the dvd spins back down, try pressing any key on the keyboard, to see if the computer continues booting without the monitor on. if so, this would suggest a monitor or video card fault. perhaps you dislodged a card or cable when changing the hard drive, check the monitor power cable, video cable, and video card are all plugged in firmly.
October 6th, 2004, 07:04 PM #11
notebook? check the contrast and brightness settings.
October 6th, 2004, 07:14 PM #12
You will need to install another version of windows first, like 98, ther use the upgrade cd. I'd use a boot disk to fdisk and reformat first.
October 6th, 2004, 07:26 PM #13Junior Member
- Oct 2004
- 6
I have tried removing the DVD drive an replacing it. It now works as far as the 3 options screen. However, in setup they ask for a disk from the previous operating system. I have W 95 and W 98 Compaq restore disks. The computer says it doesn't recognize these disks. What can I do now?
October 7th, 2004, 02:07 PM #14
NTLDR/NTKRNLMP.EXE problem
By Indigo340 in forum Technical SupportReplies: 10Last Post: October 5th, 2005, 02:58 PM -
best storage/backup system
By Koal.T in forum Storage RelatedReplies: 7Last Post: July 21st, 2004, 08:57 PM -
Large File
By eastfield in forum Applications and Operating SystemsReplies: 13Last Post: July 25th, 2003, 05:48 AM -
G3 Pricing?
By PyroSama in forum General Tech DiscussionReplies: 9Last Post: May 17th, 2003, 12:26 AM -
FREE SUPER COMPUTER...
By sKiT in forum IMO CommunityReplies: 23Last Post: April 12th, 2002, 04:12 AM
Implying a knife, ball bat, cast-iron pan, taser, or running the hell away would not have also been effective. She had the means, just not the intelligence to utilize her surroundings to her...
Do YOU think having a gun would...
