Formating Hard drive.......
Currently Active Users: 2291
Discussions: 200,919, Posts: 2,379,038, Members: 246,287
Old October 18th, 2004, 12:08 AM   Digg it!   #1 (permalink)
I currently have an 80 Gig hard drive with XP installed. What is the best way to format my drive ? I was thinking of using the fdisk feature on my ME bootdisk, would XP have a problem with this ?
Thanks...............
Network67 is offline   Reply With Quote
Old October 18th, 2004, 12:18 AM     #2 (permalink)
micfau1091's Avatar
Send a message via AIM to micfau1091 Send a message via Yahoo to micfau1091
I just use an old Win98 floppy and use dos to format...maybe barbaric, but hey....it works.
Gaming: AMD64 3K+, X1800GTO 256, 120gb7200
Personal/Living Room Gaming: (laptop)AMD64 3K+, 9700pro, 60gb5400
micfau1091 is offline   Reply With Quote
Old October 18th, 2004, 12:33 AM     #3 (permalink)
Light to Counter the Dim
MTAtech's Avatar
Send a message via AIM to MTAtech Send a message via Yahoo to MTAtech
Hold on. You want to format your current disk that has XP on it? Of course, you realize all your stuff will be erased. You could also wait until you get your new hard drive (I'm assuming you are not leaving the computer world for pencil and paper) and put your 80GB drive on as a 2nd drive and format it under your new operating system. All it will take then is a right-click.
"The Bill of Rights is my Patriot Act."
MTAtech is offline   Reply With Quote
Old October 18th, 2004, 06:15 PM     #4 (permalink)
Gilthanaz's Avatar
If you really do want to format and erase all contents, I would just boot to your WinXP cd to format and partition the drive and then reinstall the OS if thats what you plan to do.
“One things for sure: Whenever we play, our goalie stays warm.”
- Ville Nieminen, Pittsburgh Penguins
Gilthanaz is offline   Reply With Quote
Old October 22nd, 2004, 10:13 PM     #5 (permalink)
OK, My computer currently had an unlicensed copy of XP Pro installed. I purchased an OEM licensed version. I want to wipe my drive clean and and install the licensed version of Windows XP Pro. The drive has NTFS. I can't seem to format the drive with cd ?
Old October 22nd, 2004, 10:37 PM     #6 (permalink)
DoctorReno's Avatar
I would suggest doing a zero fill format of the drive and then using the XP CD to partition and format in NTFS
DoctorReno is offline   Reply With Quote
Old October 22nd, 2004, 10:38 PM     #7 (permalink)
Tazzin's Avatar
Depending on what brand of HD you have.. most of them have bootable CD's that you can use to format and partion your drive. You can download the ISO's I believe, but not sure. A basic bootable floppy with fdisk should be fine tho. I wouldnt use it to format since XP is better with the NTFS file format.
Tazzin is offline   Reply With Quote
Old October 22nd, 2004, 10:38 PM     #8 (permalink)
Umm, in english ?
Old October 22nd, 2004, 10:40 PM     #9 (permalink)
TechKnickle's Avatar
Send a message via AIM to TechKnickle Send a message via MSN to TechKnickle
People are like coins, there's always two sides.
TechKnickle is offline   Reply With Quote
Old October 22nd, 2004, 10:44 PM     #10 (permalink)
LeftCoast's Avatar
www.killdisk.com
Use this utility to zero-fill the HDD, then try installing with CD boot. If it gives you problems, make and use the 6 floppy XP start up disks. Obviously, if your only accessible computer, make the start up disks first... you can get them here.
www.bootdisk.com
EDIT: DAMN YOU, TECHKNICKLE! DAMN YOU STRAIGHT TO HELL...........
Millions long for immortality who don't know what to do with themselves on a rainy Sunday afternoon.
Susan Ertz
LeftCoast is offline   Reply With Quote
HELPPPPP Lucas2211 Technical Support 5 October 23rd, 2003 11:57 AM
upgrading mobo pinoy87 Motherboards 9 June 4th, 2003 05:04 PM
Need Major Help! ReddawgT Technical Support 32 March 26th, 2003 10:49 PM
For a Friend RedFury Technical Support 10 December 31st, 2002 10:51 AM
lowlevel formating Cook_N Technical Support 6 May 23rd, 2002 12:14 AM
Is It Just Me? (2844)
Obama the Muslim (9)
Foreign voltage (8)
Print spooler problem (10)
Virus Doctor Popup? (1)
Foreign voltage (8)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
