Results 1 to 5 of 5
    Ultimas w00t! Mastah... vikeor's Avatar
    Warsaw, Poland
    6,443
    Flash MX 2004 help...
    didnt really know what to post this :P OK, is it just me or is Flash MX 2004 wierd? i cant even make a simple button work! i make 2 keyframes, both have "stop()" then i make a button with the script "gotoandplay(2);" in the first frame and when i try it out it does nothing. In FlashMX and Flash5 this worked perfectly fine.
    AMD Opteron 146 2.8ghz 280x10
    1GB GEIL ONE S PC3200
    DFI LanParty UT NF4 Ultra-D
    ATI X1800XT @ 700/800
    Enermax Noisetaker 485W
    BigWater SE
    Newbie filipino's Avatar
    May 2004
    Philippines
    3,922
    can u post screenshot of what you did.
    Ultimate Member Tekk's Avatar
    Pasadena, CA
    2,185
    Are you sure you are not getting any type of error in the actionscript? When you test the animation inside the Flash IDE do any error windows pop-up?
    YAH! I knew you'd be jealous
    May 2004
    Philippines
    3,922
    is this what you are trying to do?
    http://wardwares.com/clickme.html
    if so download what i created here and review or see pattern and actionscript.
    http://wardwares.com/clickme.zip
    Warsaw, Poland
    6,443
    thnx filipino... i didnt add the "on release" u didnt have to do that b4 =\ kinda stupid... al works now...
    BigWater SE
  1. Flash MX problem
    By Magicfan89 in forum Technical Support
    Last Post: November 3rd, 2008, 10:30 AM
  2. Software you can't live without???
    By grandchehaw in forum Applications and Operating Systems
    Last Post: August 31st, 2004, 09:08 PM
  3. Flash mx 2004 pro action scripting help plz
    By nurdonsite2 in forum Graphic Design and Digital Photography
    Last Post: May 31st, 2004, 04:55 PM
