Thread: Win200Pro boot up problem
October 26th, 2004, 06:59 PM #1Junior Member
- Oct 2004
- 3
Hi
I've installed win2000pro on a new system, and retired the old computer.
Now running a 3.0Ghz P4 on a Aopen mobo, and a 80GB Maxtor Hdisk.
Problems start after updating to SP4 and installing all the other bits of software, such as office, Norton Firewall and NAV.
Everytime I reboot the PC, or turn it on, it wants to run checkdisk. It finds no errors and continues. Why does it want to do this everytime??
I've managed to disable it at the moment as a temporary solution, but can't see whats going wrong to cause it to want to run in the first place.
Does anyone have any ideas?
IanB
October 26th, 2004, 07:05 PM #2
I should not do that as long as you shutdown correctally. Unless there is an error with the HD. Also it normally runs scandisk if you shutdown wrong not checkdisk. Did you update to SP4 before or after you installed the other programs??
October 26th, 2004, 07:39 PM #3Junior Member
- Oct 2004
- 3
Ran the updates to SP4 before installing any other software.
Its a brand new hard drive, I've ran the maxtor diag tools, and it shows up with no faults.
Just seems odd that it leaves a dirty bit behind everytime. Is there a way of diasabling fast shutdown like you used to be able to do in win98? wonder if that is the cause.
October 26th, 2004, 07:58 PM #4
I have an earlier post similar to yours after installing more memory. Never did get an answer to the fast shutdown on 2k.
October 26th, 2004, 08:04 PM #5
See if this helps.
foolish their lack of understanding."
Ambrose Bierce
October 27th, 2004, 05:31 AM #6Junior Member
- Oct 2004
- 3
Thanks for all the help. Seems like the Cache delay fix has worked.
October 28th, 2004, 03:55 PM #7
I'm glad you posted the outcome. That fix was supposed to be only for win9x/Me but the problem seemed to be the same so I figured it was worth a shot. Glad it's fixed.
Ambrose Bierce
Boot disk issue
By pos_user in forum General Tech DiscussionReplies: 11Last Post: August 27th, 2004, 12:01 PM -
NTLDR missing and can't boot up server
By ImAn in forum Applications and Operating SystemsReplies: 0Last Post: July 16th, 2004, 05:33 AM -
So confusing....do I wait or not...
By jagnorm in forum Graphics Cards and DisplaysReplies: 12Last Post: January 21st, 2004, 06:13 PM -
ATI control panel having error
By pdxpiano in forum Graphics Cards and DisplaysReplies: 4Last Post: August 10th, 2003, 04:34 PM -
Scary crash: what happened?
By Theophylact in forum Technical SupportReplies: 23Last Post: April 21st, 2002, 05:52 PM
If you saw the hearing on TV you would have seen the Senate panel gradually being convinced that reduction in corporate income taxes (CIT) on profits is the way to go--although I suspect several of...
Senate Report on Apple Tax Dodging
