spyware and searchbar removal  | | |
December 15th, 2004, 05:30 AM
| | Ultimas w00t! Mastah...
i have all this crap on my comp stupid searchbars opening and stuff.. i scanned my system with Ad-Aware but there is no option to remove this crap only "quarantine" how can i get rid of this adware??
__________________ AMD Opteron 146 2.8ghz 280x10 1GB GEIL ONE S PC3200 DFI LanParty UT NF4 Ultra-D ATI X1800XT @ 700/800 Enermax Noisetaker 485W BigWater SE |
December 15th, 2004, 05:52 AM
| | Newbie
I miss Dimebag Darrell
December 15th, 2004, 11:36 AM
All you have to do is open AdawareSE, click on the padlock icon and then right click on the archive file you want to delete and select delete from the menu.
December 15th, 2004, 12:22 PM
i have Adaware 6.0 and theres no padlock button =\ and about buster didnt do the trick |
December 15th, 2004, 12:43 PM
ive scanned using Ad-aware SE , about buster, looked in add/remove programs and nothing =\ time to format.... |
December 15th, 2004, 12:45 PM
| | A hero in training
December 15th, 2004, 12:48 PM
December 15th, 2004, 12:50 PM
| | Best To Avoid Me
Run Spy Sweeper. ("try it" links on the right)
It will find spyware that adaware/spybot miss. |
December 15th, 2004, 01:28 PM
| | Banned
vikeor give me the name of the spyware/toolbar your trying to get rid of |
December 15th, 2004, 01:31 PM
| Quote: |
Originally Posted by vikeor i have all this crap on my comp stupid searchbars opening and stuff.. i scanned my system with Ad-Aware but there is no option to remove this crap only "quarantine" how can i get rid of this adware?? | Run a full system scan. After it finished you should be able to check all the spyware and click "next". It'll then remove everything...
BTW, do you have the latest version of AdAware?
And... if your computer is heavily infested, you might consider just formatting and reloading.
-Chris
http://www.implexant.com
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Help identifying a spyware | Ebisoba | Technical Support | 4 | August 26th, 2004 11:08 PM | | Aim | wassup123 | General Tech Discussion | 38 | August 20th, 2004 01:24 PM | | IE Toolbars | The Real Bingo | Technical Support | 14 | July 3rd, 2004 12:09 PM | | Removing Adware | Jeff_Gordon_24 | Technical Support | 12 | June 13th, 2004 01:15 AM | | pop | rubyred | Technical Support | 2 | May 23rd, 2004 01:04 PM | |
