Results 1 to 5 of 5
    Member dday's Avatar
    Sunny San Diego,Ca.
    247
    Microsoft Outlook Problem
    I'm having a problem sending email on my wife's comp. I have 2 coputers sharing a broadband connection through a router, I've been using this setup for several years. I recently reformatted and reinstalled WinXP on my wife's puter and I cannot get MS Outlook to send email. I have checked the POP and SMTP setups and they are correct. I have also uninstalled and reinstalled Outlook and still the same trouble.
    Any Input would be appreciated.
    And, Yes, I searched the archives first but didn't anyhting too similar. Even Tried MSKB and either I'm a lousy searcher, a good possibility, or I'm the only guy on the planet this has happened to. LOL
    San Diego
    125
    dday,
    Are you getting any error messages when trying to send out your email? Are you able to receive email?
    Theres no place like 127.0.0.1!
    Sunny San Diego,Ca.
    247
    It acts like it's sending the email but it never gives me an error message. What happens is the message just sits in the out box and never gets sent. Hope that helps.
    and to answer the question about receiving email, that doesn't seem to be a problem. I get email up the wazoo! I have checked the email configuration and also done the test email status in the setup and it says it's communicating with the SMTP and POP servers. I don't know what's going on.
    Yes, I have used this info and password on this pc before, that's what is confusing me.
    Sunny San Diego,Ca.
    247
    Thanks, I'll check it out!
    Fur ballin Sixpac_XP's Avatar
    Victoria, BC
    4,371
    Which version of Outlook?
    Have you done a Office Update?
  1. Outlook Express freezes when I try to open
    By Mike Kolb in forum General Tech Discussion
    Last Post: November 24th, 2004, 11:37 AM
  2. send mail via microsoft outlook
    By jilshi in forum General Tech Discussion
    Last Post: April 14th, 2004, 09:46 PM
  3. Virus and email
    By Ebisoba in forum General Tech Discussion
    Last Post: January 29th, 2004, 05:16 PM
  4. Icon changed ??
    By brunix in forum Applications and Operating Systems
    Last Post: April 19th, 2002, 10:12 PM
