Upgrade from WinXP Home to WinXP Pro
Currently Active Users: 2637
Discussions: 200,999, Posts: 2,380,010, Members: 246,369
Old March 18th, 2005, 02:14 PM   Digg it!   #1 (permalink)
I have heard many storys that Pro is much better then Home.. SO, I am planing on upgrading from Home to Pro.
My question is, do I have to do a complete format and reinstall using pro? or is there an option to over write system files and keep settings, installed programs and games? (I believe if you upgrade from Win98 to XP you're given an option like that)
vknid is offline   Reply With Quote
Old March 18th, 2005, 03:13 PM     #2 (permalink)
Mean Moderator
EvilRick's Avatar
http://www.microsoft.com/windowsxp/p...choosing2.mspx
Depending on the situation, I usually tell people that with less than 5 PCs, XP Home works in most scenarios. More than 5 and you should really consider getting Pro and maybe having a file server. Again, depending on the situation.
This signature intentionally left blank.
EvilRick is offline   Reply With Quote
Old March 18th, 2005, 04:22 PM     #3 (permalink)
Great, I like that comparison chart. I do like some of the options pro has. All the more reason for me to go pro.
Now that thats settled, that just leaves the answer to my original question. ;D
Old March 18th, 2005, 04:45 PM     #4 (permalink)
A hero in training
GroundZero3's Avatar
are you running service pack 1 or 2? If so those could be potiential problems as it might see it as you trying to go backwards.
GroundZero3 is online now   Reply With Quote
Old March 18th, 2005, 04:54 PM     #5 (permalink)
I have 2 installed. But I can slipstream pro with pack2 and burn it to a new disk. (I have done it with my Home CD)
So it is actually possible then? (with out losing data mind you)
Old March 20th, 2005, 04:02 AM     #6 (permalink)
Unregistered
Talking
you can just select upgrade option instead of a full install
or use can use the files and settings transfer wizard under system tools in the start menu
AgentCrypto is offline   Reply With Quote
Old March 22nd, 2005, 01:21 AM     #7 (permalink)
Ok so I slipstreamed SP2 into XP Pro.. it DID finally give me an upgrade option, so I went and gave it a try.
It royally screwed up my computer.
followed the directions to the T... and after it "looked" to be done and it went for the final reboot, during the Windows XP screen, I seen..... the dreaded.... blue screen of death!
After which it would restart on its own and BSOD at the same spot in a continuous loop.
SO, I lost my files.. I got most them saved from backups. but some of the resent stuff went byebye. (my bad for not backing them up sooner heh)
I have a feeling that it was my norton that jacked me. No clue what else it could have been.
Old March 23rd, 2005, 03:01 AM     #8 (permalink)
Send a message via AIM to Matrix0978
really its not possible to actually upgrade from home. its gay.
you have to delete the OS patition and then do a full install of windows xp pro.
http://s9.invisionfree.com/wdf/index.php?act=idx
Web Development forum -----^
Matrix0978 is offline   Reply With Quote
Old March 23rd, 2005, 03:07 AM     #9 (permalink)
jrsweger's Avatar
You may not be totally hosed, see this document: http://www.microsoft.com/resources/d...c_str_jyof.asp to learn how to do a parallel installation.
jrsweger is offline   Reply With Quote
Old March 23rd, 2005, 03:09 AM     #10 (permalink)
jrsweger's Avatar
Sorry about the double post, vknid if you haven't already reformatted, can you provide the error code for the blue screen of death?
Win2k does not enter Win XP Home Fanzoo Networking and Internet 9 June 2nd, 2003 03:34 AM
Replace Corrupt files...SFC on WinXP Pro ??? theonetruegod Applications and Operating Systems 1 February 5th, 2003 08:42 AM
WinXP pro Logon to Win2k network (at home) Lord Locksley Networking and Internet 4 February 19th, 2002 12:00 PM
XP Pro Clean Install or PreLoaded Home XP? Mortis Applications and Operating Systems 6 February 12th, 2002 12:57 PM
WinXP Home can't join a Domain PonzSpyder Networking and Internet 10 January 16th, 2002 01:40 AM
Is It Just Me? (3111)
‘Rogue’ or ‘Rouge’? (9)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Laptop with wireless problem. (13)
add ram to existing (4)
Delete an OS (18)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
