using xcopy in dos
Currently Active Users: 1467
Discussions: 200,956, Posts: 2,379,485, Members: 246,317
Old February 27th, 2002, 06:58 PM   Digg it!   #1 (permalink)
S.D.Willie's Avatar
Send a message via AIM to S.D.Willie
using xcopy in dos
hi,
booting with a startup disk:
whats the long dos command to copy all files, directories, and sub directories in dos? dont you have to have xcopy on the bootdisk for xcopy to work? if so i dont think xcopy comes on a win98 boot disk.
i just want to copy all files and folder off a cd to a directory. thanx
S.D.Willie is offline   Reply With Quote
Old February 27th, 2002, 07:01 PM     #2 (permalink)
FalcomPSX's Avatar
Send a message via ICQ to FalcomPSX Send a message via AIM to FalcomPSX
xcopy is in the windows\command directory
it is NOT on a windows startup disk by default.
copy the xcopy file, the xcopy32 file and one other xcopy.(something) file. 3 total files needed.
then at the command prompt type xcopy [source] [dest] /s(coppies subdirectories) /e(coppies empty directories)
that should do it!
FalcomPSX is offline   Reply With Quote
Old February 27th, 2002, 07:19 PM     #3 (permalink)
S.D.Willie's Avatar
xcopy doesnt work under dos in xp. i shoulda mentioned it was XP. i know surreal posted somewhere about this long command(if possible) but i cant seem to find it. ugh
Old February 27th, 2002, 08:02 PM     #4 (permalink)
strangerstill's Avatar
In XP xcopy.exe is in windows\system32.
According to help and ntcmds.chm it is available, in cmd.exe at least...
If you're using a 98 boot disk you'll need the 98 version of xcopy.
strangerstill is offline   Reply With Quote
Is It Just Me? (2943)
Print spooler problem (15)
Some methods to retrieve lost Windows.. (0)
lost Windows user name and password (13)
whats the fastest dvd ripper? (13)
How to Convert Blu Ray Disc Movie to .. (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
