Results 1 to 10 of 10
    Jan 2002
    Cali4ya
    161
    control volume while burning mp3's?
    okay, what software can i use to burn mp3's on a cd that can control the volume settings? because some songs are louder than others and some are just to low. i am using nero.....
    norml.org thekingofpain's Avatar
    SoCal
    5,434
    Try this for information: http://www.noteworthysoftware.com/nwcforum/1/1385.htm
    Senior Member deltaf508's Avatar
    Colorado
    688
    No problem at all with Nero. It's built in. All you have to do is right click on the song title and selelct "properties" then select "Filters" I believe. There should be a normalize check box. Just check the button and go with the default value that nero gives you. That's it. Make sure all your songs have this checked. Simple as that. Also this will significantly increase your "burn time" because Nero has to think more.
    BTW: Nero 5.0 and later allow you to select multiple files at once and set properties for all of them at one time. Previous to 5.0 you had to do them one at a time.
    Hope this Helps,
    Gary
    Feb 2002
    NJ, USA
    33
    I was not aware of that. Thanks!
    Epyon--Taking user error to a whole new level
    Ultimate Member S.D.Willie's Avatar
    Ranger Country
    2,534
    Thumbs up
    ditto.
    Feb 2002
    Toronto, Canada
    29
    Hope this Helps,
    Gary
    I tried this and it only seems to work if you want to create .CDA music CDs from MP#s.
    What I am trying to do, and I presume that's what dar1again wants to do as well, is to burn the MP3s to CD leaving them in MP3 format but be able to normalize the volumes.
    Jan 2002
    Cali4ya
    161
    That's exactly what i want to do.
    1,429
    Thumbs up
    I learned something new today, thanks!
    Ultimate Member robin801's Avatar
    philadelphia pa
    1,518
    when u pay for musicmatch it has a normalizing feature.
    and u can burn a cd from musicmatch.
    robin
    always wanting to learn something new
    robin
    Colorado
    688
    yeah, to do that you will have to get another 3rd party program and normalize them first, then put them into nero on a disk. I guess I missinterpreted what you meant. At least I helped some others.
    It looked like these guys had some software that would do the job. just did a search in google so I I've never used it before.
    Various Mp3 Software
    Hope this helps,
    Gary
    Hey: My 300th post. Yeah.
