Need help stopping win messenger
Currently Active Users: 1729
Discussions: 200,924, Posts: 2,379,124, Members: 246,290
Old June 30th, 2005, 04:18 AM   Digg it!   #1 (permalink)
JacobM5727's Avatar
Send a message via ICQ to JacobM5727 Send a message via AIM to JacobM5727 Send a message via Yahoo to JacobM5727
i got some windows updates, and sure enough - i have the windows messenger plague once more
add/remove programs shows it as uninstalled
i have outlook express set not to log onto it when i open it
open outlook express, sure enough - windows messenger opens
i know there is a way to stop that bs but i cant remember how
oh, something i just noticed - when i close outlook express, it closes messenger too.. i have messenger set not to run in background, and to not start with the computer..
disabled access to windows messenger through add/remove - no effect
ok, being the patient guy i am, i just deleted the folder for messenger (seems to be fine)
--Jacob--
JacobM5727 is offline   Reply With Quote
Old June 30th, 2005, 06:05 AM     #2 (permalink)
jrsweger's Avatar
See your other thread that you started, it will or should lead you to your answer!
jrsweger is online now   Reply With Quote
Can't shut down or remove Windows Messenger, interferes with MSN Messenger ArcticFox Technical Support 8 July 25th, 2008 12:15 AM
stopping the dust.. reiss PC Modification 12 March 12th, 2005 11:55 PM
Stopping print wizards NeoStarO1 Technical Support 4 June 3rd, 2003 04:59 AM
Win XP Pro with Windows Messenger a Repalcement for Net Meeting? surreal Applications and Operating Systems 1 January 28th, 2002 01:53 PM
Stopping startup programs in Win 95 Sanman Applications and Operating Systems 5 December 6th, 2001 04:59 PM
Is It Just Me? (2865)
Obama the Muslim (14)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
