Well, if its all one word I think it might do that regardless.
But in general, just define static widths for the cells and the whole table. Or you can use percentages. Just make sure everything adds up, or it will stretch to fill gaps and browsers might interpret it differently
You can do it in the code, or by selecting the table itself (click in a cell, and then right click --> table --> select table) and using the properties bar
