August 12th, 2005, 07:55 PM #1
Oh help, changed my second drive, now XP will not boot
I swapped my old D: drive with a new drive. Went from a IDE 133 to Sata.
I ghosted the old drive to the new drive to transfer my files.
Changed my bios to reflect the new boot order.
XP now hangs with nothing but a blank screen ( I have the startup screen disabled).
I can boot to safe mode, so the C: is still fine.
I went into device manager and removed all the drives and rebooted. Still hangs.
It hangs even with just one drive connected.
My main drive is NTFS, the second is Fat32.
I'm running WinXP Home, SP2Asus M4A785TD-V EDO, Phenom II X4 945 Deneb 3.0GHz 4 Gig DDR3 1333 Win7 64 Home
August 12th, 2005, 08:05 PM #2
Did your forget your sata drivers?
Old Cranky and hard of hearing
I-5, 3450 socket 1155, 16gb 1066ram corsair vengance
PNY GeForce GTX 670
August 12th, 2005, 08:21 PM #3
The first drive is Sata, so it has the drivers.
This was a working install, but I wanted to replace the old IDE drive with a new SATA.
I messed around with bootcfg, now have two boot options. I'm about to start from scratch, but I'd like to fix this.
I ghosted my main drive this morning, so I could restore all the old hardware and software and try again.
XP does not seem to be very understanding about hardware changes. W98 let you swap drives around all day, so long as the boot drive stayed the same drive letter.
This is twice now that I have screwed up XP by moving drives.Asus M4A785TD-V EDO, Phenom II X4 945 Deneb 3.0GHz 4 Gig DDR3 1333 Win7 64 Home
August 12th, 2005, 08:56 PM #4
I sympathise with you cause I done it too.
PNY GeForce GTX 670
August 13th, 2005, 09:51 AM #5
I gave up trying to fix, now starting over.
I now can not get the Nivida chipset drivers installed properly, seems something has changed and now will not work.
hardware is all the same except for the hard drive swap.
New problem, I'll start a new thread.Asus M4A785TD-V EDO, Phenom II X4 945 Deneb 3.0GHz 4 Gig DDR3 1333 Win7 64 Home
August 13th, 2005, 10:08 AM #6
good luck amdkt7
PNY GeForce GTX 670
Change boot drive in dual-boot system
By ElViti in forum Applications and Operating SystemsReplies: 15Last Post: June 30th, 2008, 07:15 AM -
wont let me boot sata drive without IDE drive
By paul.uk in forum Storage RelatedReplies: 4Last Post: January 8th, 2005, 10:13 AM -
changed HSF now no boot
By [Neo770] in forum Technical SupportReplies: 7Last Post: September 26th, 2003, 11:41 PM -
Drive will not format with win98 boot disc, but with XP boot disk?
By Bizkitkid2001 in forum Storage RelatedReplies: 7Last Post: April 25th, 2003, 02:33 AM -
Changed mobo and cpu, XP harddrive will not boot, but 98 does
By bskit88 in forum Technical SupportReplies: 6Last Post: December 20th, 2002, 06:19 PM
"The sequester will never happen" "it will be too bloody for anyone to allow" RIGHT. What I want is for the CONGRESSMEN who allowed it to be punished. Not people like you an me. I still have no...
Happy Sequester Furlough Friday!
