September 22nd, 2005, 09:30 AM
| Senior Member
I'm trying to make this CD autoplay when it's entered into a PC, and basically I want the file "Home.html" to be loaded.
I've tried using the ShellExecute command, but to no avail.
The file I want to load "Home.html" is located in the "Docs" folder on the CD.
The "Autorun.inf" file is in the root directory of the CD, so I know that's correct.
How do I tell the Autorun.inf file to look in docs to autorun the home.html file?
IT Noob
