Changing Operating systems
Currently Active Users: 2550
Discussions: 200,996, Posts: 2,379,944, Members: 246,364
Old September 27th, 2005, 09:05 PM   Digg it!   #1 (permalink)
I want to remove the windows 200 from my pc and install windows 98. I have a reason for doing this.
I just need help with it.
I want to just remove the operating system if possible.
I have a copy of 98 that I will install after 2000 is gone.
Please give me step by step help.
Joe
joe53081 is offline   Reply With Quote
Old September 27th, 2005, 09:21 PM     #2 (permalink)
It's the cheese guy! ¬_¬;
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
This will take a full format and reinstall. Everything will be wiped from your hard drive. You will need to backup all essential data before you start.
You should probably go to www.bootdisk.com to get a program which makes a windows boot floppy, and make one of those before you start. Get either the windows98se or the windows Millenium Edition (ME) version.
paul9 is offline   Reply With Quote
Old September 27th, 2005, 09:31 PM     #3 (permalink)
Father V2.0
washe's Avatar
Send a message via MSN to washe
Basically you will need to erase the current partition and create a new one to hold the operating system. be warned that doing that you will lose all your data, I suggest you backup all your personal and criticall data before starting..
Windows 98 comes with a floopy boot disk or a bootable CD, insert that one and boot with it (it will need to boot from the floppy or CD not from the harddisk, if it goes directly to windows 2000 then you need to change your boot order in the bios to Floopy and CDROM first, refer to your manual to how to it)
You will need to run in the command prompt FDISK
In FDISK you will erase the current partition in C and create the new partition in C, after that you will need to format drive C:
reboot, and the harddisk will be ready to hold windows 98
Then proceed with windows 98 install.
someone is more skilled than you!
http://s7.bitefight.org/c.php?uid=23753
washe is offline   Reply With Quote
Delete one of the operating systems on my pc mrsparky Applications and Operating Systems 10 August 31st, 2005 05:23 PM
Ancient Operating Systems EvilRick Applications and Operating Systems 60 July 24th, 2004 01:42 PM
Using two operating systems 670bird Technical Support 6 December 10th, 2003 12:19 PM
2 operating systems (but not really)? Pollo-Diablo Technical Support 2 December 9th, 2003 11:18 PM
two operating systems vietboi General Tech Discussion 16 October 31st, 2003 11:40 AM
Is It Just Me? (3092)
Foxconn Blackops x48 MoBo (5)
Health Care Rationing (16)
Nvidia GTX 260 problem (14)
Delete an OS (17)
Laptop with wireless problem. (13)
[F@H SPAM 11/16/09] ! 1/2 months to.. (41)
add ram to existing (0)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (41)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
