Thread: Help backing up a disk
October 22nd, 2005, 11:49 PM #1
First of all, I bought FEAR a few days ago...and I know how easily disks around here get scratched so bad that they can't be used after a while...so I tried to make a backup...but I have some trouble...
First thing I did was copy it using clonecd into an R file...then I burned it onto a spare dvd I have...and everything seemed to work fine...untill I tried running Fear with the backup disk...then it said that it could not find the original disk...
So, onto my question...how do I make it act like the original disk so I can use it instead of the original?
October 23rd, 2005, 12:29 AM #2
It has been awhile since I have tried to backup a Game onto another disc. I don't have CloneDVD so I don't know how that works. Is it a game on a DVD? Is it dual layer? If it is a dual layer DVD-9 disc then you would have to burn it to a DL-DVD.
I would try a different program to try and back it up like Nero.
October 23rd, 2005, 12:31 AM #3
Yes, it is a dvd, and it is not a dual layer.
I will see if it will work with nero.
October 23rd, 2005, 01:17 AM #4
Nope, same thing with nero.
October 23rd, 2005, 11:28 AM #5
I don't use Nero but in Roxio I use disk copier and it works for me.
You can't get there from here
October 23rd, 2005, 01:04 PM #6
You mean you tried fear in roxio, and it worked?
October 23rd, 2005, 09:09 PM #7
Bump for the night people.
October 23rd, 2005, 09:12 PM #8
It is most likely a protected disk and you'll need a program specifically made to copy [oh, I mean back up] that type of disk.
Benjamin Franklin
October 23rd, 2005, 09:16 PM #9
Well, I tried CloneCD...and Nero...what else should I try?
DISK BOOT ERROR, INSERT SYSTEM DISK AND PRESS ENTER
By sm8000 in forum Technical SupportReplies: 6Last Post: September 29th, 2005, 11:35 PM -
What's better for backing up?
By ClubMed in forum General Tech DiscussionReplies: 16Last Post: April 7th, 2005, 09:39 AM -
Backing up
By Tygur in forum General Tech DiscussionReplies: 3Last Post: June 18th, 2002, 05:08 AM -
Backing up
By Cruez in forum General Tech DiscussionReplies: 13Last Post: February 24th, 2002, 12:05 PM -
All I did was run Disk Doctor and Speed Disk... now Windows wont start
By Someotheral in forum Technical SupportReplies: 13Last Post: December 20th, 2001, 10:49 PM
I know there is plenty of tutorials for putting Snow Leopard on a PC but I couldn't find one particular to what I have. I have a Laptop with Windows 7 on it. I really don't use it for anything and...
