drive became Prpq---recover the file help
Currently Active Users: 1939
Discussions: 200,511, Posts: 2,374,419, Members: 245,834
Old December 17th, 2005, 12:49 PM   Digg it!   #1 (permalink)
Post
hi friends,
I am in bit of problem ,Using PowerMagic to move the drive(actually resizing c:\ for this I moved d:\) my system got restarted when operation was in progress........
Now when system started my D:\ became Prpq and option which were shown by
PowerMAgic were to delete or format
I wanted to recover the data what r other possibilities also I tried to format it and also as my lat option I tried to delete it none worked .
Can anyone help......................................
Nikhil
nikhil is offline   Reply With Quote
Old December 17th, 2005, 11:34 PM     #2 (permalink)
Banned
It's time for a data recovery software to come in there. If you can slave the drive to another
you might be able to retrieve files that weren't wiped when trying to format and delete. The
data recovery softwares out there can be a big help if the drive has become inaccessible if
you try setting it up as a slave.
http://www.pctools.com/file-recover/...OVMTC=standard
PC TECH250 is offline   Reply With Quote
Old December 17th, 2005, 11:57 PM     #3 (permalink)
No pants, Wearin'a Helmet
MitaDC's Avatar
Send a message via ICQ to MitaDC Send a message via MSN to MitaDC Send a message via Yahoo to MitaDC
for future reference, you do not want to format a hd if you are looking to recover data, that deletes the data (well it actually doesn't delete it unless you do a low level format, but that is a different story). Hopefully the data recovery software can recover it for you. As you will probably find, the software is pretty spendy and even though u can find tons of free downloads, most, if not all, will only recover a few files and then require you to purchase the product to use it to recover everything. GL
Dr. Cox -Newbie, Stay. Oohhh what a good boy you are, Newbie..... DEAR GOD JUDY HOW MUCH PRODUCT DO YOU USE?
J.D -None. It's like this when I wake up
MitaDC is offline   Reply With Quote
Old December 18th, 2005, 12:02 AM     #4 (permalink)
It's full of stars ¬_¬;
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
I'd expect to kiss my files goodbye after this. Make some Partition Magic rescue discs and restart the computer to boot from those. It should recognise a failed partition attempt and offer some recovery or other options. It's a while since I used it, so I can't remember the exact procedure.
paul9 is offline   Reply With Quote
Old December 18th, 2005, 12:44 AM     #5 (permalink)
Banned
Whenever performing any changes to partitions important data should already be backed
up by an external means to prevent loss if something goes wrong in the process. The link
here as well as some costly softwares are still no guarantee of a full recovery of files stored
on a drive. There are some softwares as well as tech services that claim to be able to get
files off of a drive after they have been deleted. That remains to be seen.
Old December 18th, 2005, 01:02 AM     #6 (permalink)
paul9's Avatar
Nope, that's a proven fact. Norton has a fairly comprehensive undelete utility, there are unformat utilities around, too. The complication in this case is that PM was busy moving things around on the drive, and may have screwed up a lot of file metadata, leaving files unrecoverable. A sector editor may still be able to recover this stuff, but it is not necessarily easy or quick.
Old December 18th, 2005, 01:49 AM     #7 (permalink)
Banned
"That remains to be seen." mainly refers to the claims advertised by some services. There
are some excellent softwares availble for a price. Another alternative is to try a demo if this
is a one time event. http://www.recovermyfiles.com/
Old December 18th, 2005, 02:17 PM     #8 (permalink)
blubomber's Avatar
Send a message via MSN to blubomber Send a message via Yahoo to blubomber
I have had alot of good success with a program called Easyrecovery. There are a few different versions of the program but i was able to recover files from a drive once that was formatted twice. Not low level format but just using the windows format.
http://www.ontrack.com/easyrecoverydatarecovery/
Like it has been said, try to set the drive you want to recover the data off of as a slave to another in another system. do not reinstall windows or any programs on the drive before you try to recover files becasuse you could end up over writting files.
Good Luck!
"Life moves pretty fast, if you dont stop to look around once in a while, you could miss it." -FB
blubomber is offline   Reply With Quote
Recover a deleted file Coolzer Technical Support 9 November 7th, 2005 01:33 AM
recover file ClubMed General Tech Discussion 3 May 25th, 2005 05:51 AM
Recover an overwritten file Ebisoba Technical Support 1 November 4th, 2004 12:48 PM
Anyway I can recover a shift-deleted file? 404 General Tech Discussion 4 July 7th, 2004 09:15 AM
how do I recover a chkdsk'd file after a crash? rh71 Applications and Operating Systems 2 November 6th, 2002 11:20 PM
Is It Just Me? (1636)
windows 7 retail and rtm (5)
Review My Build (6)
Assosiations (21498)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
