Join TechIMO for Free!
Topic: Hi! all of a sudden my desptop icons have gone blue. i cant get them to default as it was in WinxXP???! i didnt change the colors of the icon ever?? pls let me know how to get it ,,back? dnt think any malware or...
Thread Tools
Currently Active Users: 1553
Discussions: 186,254, Posts: 2,222,983, Members: 229,817
Old March 22nd, 2006, 01:39 PM     #11 (permalink)
Foggy's Avatar
Download and install Tweak UI, it has an option to rebuild icons
You can't get there from here
Foggy is offline   Reply With Quote
Old March 22nd, 2006, 01:45 PM     #12 (permalink)
Registered User
i was too lazy to look up the manual fix for rebuilding the icon cache myself, but if tweakUI has that functionality i'd say it's the way to go.
if it doesn't work, definitely go with the profile idea (can't beleive i didn't htink of that!) as it will narrow down where the cause of the problem is.
johnnyis42 is offline   Reply With Quote
Old March 23rd, 2006, 01:06 AM     #13 (permalink)
if you do find out the cause, be sure to let us know, curiosity
holdensrule is offline   Reply With Quote
Old May 3rd, 2006, 07:58 AM     #14 (permalink)
The same thing happened to me today while I was tweaking my mate's computer. I found this thread while I was researching the problem. At the bottom of this page in "Similar Threads" I found this piece of advice:
Try:
Control panel
System
Advanced
Performance
Settings
In the visual effects, click "Adjust for best performance"
I haven't had a chance to try it on my mate's computer yet, but hopefully it will work for you......if not there was some other good advice in the same thread "icons on desktop".
All the best.....
Byron172 is offline   Reply With Quote
Old May 16th, 2006, 11:58 AM     #15 (permalink)
Hi, don't know if anyone is still reading this, but i had the same problem and solved it by - right clicking on the desktop - click on "arange icons by" - then uncheck "lock web items on desktop" This worked for me, hope it helps.
Still no idea why it turned itself on screen saver also turned itself on, strange!!!
1ellis2345 is offline   Reply With Quote
Old January 13th, 2007, 11:37 PM     #16 (permalink)
To have transparent icons:
1) Hold down the Windows key and press Pause/Break. On the "Advanced" tab,
under "Performance" click "Settings." On the "Visual Effects" tab, make sure
the box "Use drop shadows for icon labels" is checked.
2) Right-click on the Desktop, and make sure that "Arrange Icons by" "Lock
Web items" is not checked.
3) Right-click on the Desktop, and choose Properties. Othe "Desktop" tab,
click "Customize Desktop," then on the "Web" tab, uncheck all boxes.
4) Make sure any Wallpaper is an image file. Html will stop the
transparency.
anishluv is offline   Reply With Quote
Old January 21st, 2007, 08:03 AM     #17 (permalink)
Thumbs up
This problem happened to me last night, for no apparent reason. I panicked at first, because I thought it must be a virus but I have fixed it now.
It appears to be a WIndows problem (so no surprise there!). All of the desktop icons turned into that little television described, except for some random WIndows icons, like Word. That suggested that it was a WIndows problem and gave me hope.
I tried everything suggested in this thread and nothing worked. What worked for me was this:
Went into Control Panel - Display-Appearance-Effects.
Checked Use Large Icons box and everything came back! Amazing!
After I was sure everything was back to normal, I then unchecked the box again and so far everything is still okay. Hope this works for you!
Puddock is offline   Reply With Quote
Old May 7th, 2008, 05:52 AM     #18 (permalink)
Angry
I've got same problem.......
I did some stupid stuff caught a virus or spyware, it changed my wallpaper and text under the icons are outlined in dark blue. I've ran a variety of spyware and virus programs which find something each time but doesn't seem to get rid of it. When I'm online the webpage I'm on will switch to something I've never heard of. When I look in iexplorer prop.s cookies it shows tons of pages I have not visited. If i delete them and comeback a few minutes later cookies is full again!
boomer31 is offline   Reply With Quote
Old November 14th, 2008, 10:49 AM     #19 (permalink)
SiliconJon's Avatar
Someone ran across a similar issue today on an XP Pro system. It was with a URL shortcut on the desktop, but it didn't turn blue - it turned into a red ball, which is not an icon at all associated with the site at the URL. Manually changing it back to the blue E for IE7 does not keep, so we will be trying the following:
• Deleting & recreating the shortcut
• Right-click desktop > arrange icons by > uncheck: lock web items on desktop
o Also: Display properties > Desktop > Customize > Lock Desktop Items
• Deselect “show web content” from Active Desktop settings
o (How to enable / disable windows active desktop.)
• Ctrl Panel > System > Adv > Perf > Settings > Visual Effects > toggle between settings to see if corrected icon remains
• Display > Appearance > Effects > Toggle icon size and/or settings
• Delete (or better yet rename *.old) IconCache.db
"We are on the verge of global transformation. All we need is the right major crisis..." David Rockefeller
SiliconJon is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Icons on desktop. hatehotmail General Tech Discussion 9 February 14th, 2006 02:25 PM
desktop icons gone Mombo323 Technical Support 2 February 10th, 2006 10:15 PM
icons on desktop seanmark2 General Tech Discussion 6 January 20th, 2004 12:41 AM
desktop icons sirduke Applications and Operating Systems 6 March 26th, 2003 01:57 PM
icons on desktop? Creatures Applications and Operating Systems 14 March 8th, 2003 10:03 PM
Is It Just Me? (16993)
FolderChat: Weekend time again! (313)
The F word (under-utilized or horri.. (43)
So GLAD winter's finally here !! (27)
Motherboard installation (8)
Folderchat Weekday thread (373)
no good at fps.... (6)
Super folding (20)
Popular Online Pc Retailers (12)
help (0)
My Best OC Ever (7)
HP Combo 535r problem... (0)
can anyone recomend a 1KW psu?? (4)
vista will not load (0)
New info on the Phenom II X4 (5)
Web Hosting and Domain? (16)
nc 6000 problems...LEDs remain .. (2)
9800GTX 512meg (9)
Six 28-Disc Cross Design Black .. (1)
FS: New Benny Hill Megaset DVD .. (1)
