March 22nd, 2006, 01:39 PM
#11 (permalink)
Download and install Tweak UI, it has an option to rebuild icons
You can't get there from here
March 22nd, 2006, 01:45 PM
#12 (permalink)
| | Registered User
i was too lazy to look up the manual fix for rebuilding the icon cache myself, but if tweakUI has that functionality i'd say it's the way to go.
if it doesn't work, definitely go with the profile idea (can't beleive i didn't htink of that!) as it will narrow down where the cause of the problem is. |
March 23rd, 2006, 01:06 AM
#13 (permalink)
if you do find out the cause, be sure to let us know, curiosity  |
May 3rd, 2006, 07:58 AM
#14 (permalink)
The same thing happened to me today while I was tweaking my mate's computer. I found this thread while I was researching the problem. At the bottom of this page in "Similar Threads" I found this piece of advice:
Try:
Control panel
System
Advanced
Performance
Settings
In the visual effects, click "Adjust for best performance"
I haven't had a chance to try it on my mate's computer yet, but hopefully it will work for you......if not there was some other good advice in the same thread "icons on desktop".
All the best.....
May 16th, 2006, 11:58 AM
#15 (permalink)
Hi, don't know if anyone is still reading this, but i had the same problem and solved it by - right clicking on the desktop - click on "arange icons by" - then uncheck "lock web items on desktop" This worked for me, hope it helps.
Still no idea why it turned itself on screen saver also turned itself on, strange!!! |
January 13th, 2007, 11:37 PM
#16 (permalink)
To have transparent icons:
1) Hold down the Windows key and press Pause/Break. On the "Advanced" tab,
under "Performance" click "Settings." On the "Visual Effects" tab, make sure
the box "Use drop shadows for icon labels" is checked.
2) Right-click on the Desktop, and make sure that "Arrange Icons by" "Lock
Web items" is not checked.
3) Right-click on the Desktop, and choose Properties. Othe "Desktop" tab,
click "Customize Desktop," then on the " Web" tab, uncheck all boxes.
4) Make sure any Wallpaper is an image file. Html will stop the
transparency. |
January 21st, 2007, 08:03 AM
#17 (permalink)
This problem happened to me last night, for no apparent reason. I panicked at first, because I thought it must be a virus but I have fixed it now.
It appears to be a WIndows problem (so no surprise there!). All of the desktop icons turned into that little television described, except for some random WIndows icons, like Word. That suggested that it was a WIndows problem and gave me hope.
I tried everything suggested in this thread and nothing worked. What worked for me was this:
Went into Control Panel - Display-Appearance-Effects.
Checked Use Large Icons box and everything came back! Amazing!
After I was sure everything was back to normal, I then unchecked the box again and so far everything is still okay. Hope this works for you! |
May 7th, 2008, 05:52 AM
#18 (permalink)
| I've got same problem.......
I did some stupid stuff caught a virus or spyware, it changed my wallpaper and text under the icons are outlined in dark blue. I've ran a variety of spyware and virus programs which find something each time but doesn't seem to get rid of it. When I'm online the webpage I'm on will switch to something I've never heard of. When I look in iexplorer prop.s cookies it shows tons of pages I have not visited. If i delete them and comeback a few minutes later cookies is full again! |
November 14th, 2008, 10:49 AM
#19 (permalink)
Someone ran across a similar issue today on an XP Pro system. It was with a URL shortcut on the desktop, but it didn't turn blue - it turned into a red ball, which is not an icon at all associated with the site at the URL. Manually changing it back to the blue E for IE7 does not keep, so we will be trying the following:
• Deleting & recreating the shortcut
• Right-click desktop > arrange icons by > uncheck: lock web items on desktop
o Also: Display properties > Desktop > Customize > Lock Desktop Items
• Deselect “show web content” from Active Desktop settings
o ( How to enable / disable windows active desktop.)
• Ctrl Panel > System > Adv > Perf > Settings > Visual Effects > toggle between settings to see if corrected icon remains
• Display > Appearance > Effects > Toggle icon size and/or settings
• Delete (or better yet rename *.old) IconCache.db
"We are on the verge of global transformation. All we need is the right major crisis..." David Rockefeller
| You may post new threads You may post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Icons on desktop. | hatehotmail | General Tech Discussion | 9 | February 14th, 2006 02:25 PM | | desktop icons gone | Mombo323 | Technical Support | 2 | February 10th, 2006 10:15 PM | | icons on desktop | seanmark2 | General Tech Discussion | 6 | January 20th, 2004 12:41 AM | | desktop icons | sirduke | Applications and Operating Systems | 6 | March 26th, 2003 01:57 PM | | icons on desktop? | Creatures | Applications and Operating Systems | 14 | March 8th, 2003 10:03 PM | | Most Active Discussions | | | | | Recent Discussions  | | | | | |
