Results 1 to 19 of 19
    Member AFMAN10's Avatar
    Nov 2005
    Denver, Colorado
    244
    Exclamation Problems with watching videos.
    This is really strange, I’ve never seen anything like it.
    No mater what program I use to watch videos, even DVDs I get the same result.
    Instead of seeing the video, I see a green sometimes black square. I still get sound but I don’t see the video!
    This is getting really frustrating.
    If I reboot the computer, then I can watch videos for a little while, but eventually I cant watch them. Is there something installed on my PC that is stopping the video from playing?
    I ran multiple Spy-ware and Registry fixing programs and I still have this problem…
    Anyone have any ideas?
    Ultimate Member mjolnir1134's Avatar
    Jan 2005
    The Internet
    1,997
    First off, like everyone else is a thinkin', I'd check to update drivers. Video drivers to say the least.
    Windows XP I'm assuming right? xP
    EEE 1000H—1.6Ghz—1GB RAM—XP
    Nov 2005
    Denver, Colorado
    244
    yes windows XP... i already did that a few days ago, forgot to mention it... still didnt help
    Jan 2005
    The Internet
    1,997
    Codec problem perhaps? (running out of suggestions already )
    Well, have you installed something recently that could've started the problem?
    Nov 2005
    Denver, Colorado
    244
    it cant be a codec proble... i mean, it happends with DVDs as well, and with videos that worked before, sometimes they work, but usually they dont.
    i cant think of anything that i have installed recently.
    Jan 2005
    The Internet
    1,997
    How about anything running in the background that could possibly screw with your media player's video player?
    I'd get a hijackthis log going into hijackthis.de
    Nov 2005
    Denver, Colorado
    244
    thanks, i only got one error, the rest was classified 'safe'
    i dont know what i shoud do with it:
    O2 - BHO: CVirtualDNSObj Object - {86C510E9-97EF-4749-914F-0280247BE3A6} - (no file)
    Unnecessarily Entries found in this registry zone are potentially nasty. This application ([86C510E9-97EF-4749-914F-0280247BE3A6] - Result: 86C510E9-97EF-4749-914F-0280247BE3A6) has been checked. Hit rate: 100,00%
    Must be fixed!
    Unnecessary (deactivated) entry that can be fixed.
    what should i do? what will hapend after i do it? could this be my problem?
    Nov 2005
    Denver, Colorado
    244
    well... i deleted that entry, but that didnt help, i'm still having the same problems.
    Nov 2005
    Denver, Colorado
    244
    anyone?
    A#1
    A#1 is offline
    Feb 2006
    445
    what kind of video card...i'm thinking overheating...do you do any gaming...if so do they flake out after playing for a while...anyway if you haven't done so if it was me i'd open up my case and give everything a good cleaning with some canned air especially if your card has a built in fan clean around it real good.
    I'm gonna get the Duke and John Cassavetes and Lee Marvin and Sam Pekinpah And a case of Whiskey and drive down to...
    Aug 2003
    Madison, WI
    15,225
    Hey AFMAN!
    Haven't seen you in a while.
    Yep, clean out the dust in your pc first...
    Just for kicks try VLC media player to play the movie...
    http://www.videolan.org/mirror.php?f....8.5-win32.exe
    Nov 2005
    Denver, Colorado
    244
    hey EX... been a while....
    anyway, i got a can of compressed air and cleaned out my system real good... it really needed it too. But the problem is still there... i've tried the VLC player a few days ago and still had the same problem... is my video card bad? i mean, everything els works, i can play games and use photoshop etc. with no problem, its only with videos that i am having this problem.
    分かりますか。 carl33p's Avatar
    Feb 2006
    Gville, FL
    7,170
    9
    What GPU?
    Could try some different drivers. Reseat your GPU. Make sure the wire connection to your moniter are secure. (Just trying to throw out some ideas )
    Aug 2003
    Madison, WI
    15,225
    Ya, try what carl said.
    When your not going to do anything with it for a few hours, I would have it run memtest to check the ram(I don't think it's the ram, since everything else seems fine, but you never know).
    www.memtest86.com
  15. #15
    A#1
    A#1 is offline
    Feb 2006
    445
    Quote Originally Posted by AFMAN10
    hmm...everything seems fine working from your hard drive...wonder if its a prob with your optical drive...i've never had to clean the laser eye thing in one of mine...maybe somebody else can suggest how to..
  16. #16
    Nov 2005
    Denver, Colorado
    244
    thanks A#1, but this happends with regular mpg and AVI' as well... not just DVDs.
  17. #17
    A#1
    A#1 is offline
    Feb 2006
    445
    maybe try copying a movie file to your hard drive and see what happens...from what all you've done and the way things are going i still wouldn't rule out your optical drive going belly up on you...do you have a spare drive or one you can borrow to see if thats the prob?
  18. #18
    Nov 2005
    Denver, Colorado
    244
    Well, mpg and avi' are already on my hard drive, they are not DVDs; I'm not playing them from an optical drive. I also have 3 hard drives with videos on each, I tried all 3 and they are all having the same problem. I find it hard to believe that 3 hard drives all went bad at the same time.
  19. #19
    A#1
    A#1 is offline
    Feb 2006
    445
    lol...i didn't mean you hard drives...well anyways you answered my question your not even able to play files from your hard drive...so that rules out any issue of a bad optical drive....have you tried a different codec pack...personally i like the 'ffdshow codec pack' maybe give it a try...
    Code:
    http://www.free-codecs.com/download/FFDShow.htm
  1. I'm watching you!
    By Santa Claus in forum IMO Community
    Last Post: November 22nd, 2005, 06:08 PM
  2. Problems watching movies
    By gillhoose in forum Multimedia and Audio
    Last Post: December 10th, 2004, 03:15 PM
  3. Black dots when watching videos
    By skill52 in forum Technical Support
    Last Post: July 22nd, 2004, 11:56 PM
  4. Well, whose watching it?
    By ILC in forum IMO Community
    Last Post: May 7th, 2004, 03:51 PM
  5. Can someone tell me what I'm watching
    By OuTpaTienT in forum IMO Community
    Last Post: July 5th, 2002, 06:08 PM
