Should have built my own
Currently Active Users: 2110
Discussions: 200,919, Posts: 2,379,057, Members: 246,287
Old August 24th, 2006, 10:16 AM   Digg it!   #1 (permalink)
Mombo323's Avatar
Send a message via Yahoo to Mombo323
I now have a Compaq Presario PC. 3.20 gigs, 512 megs of ram. Only questions I have is.. First of all, it came LOADED with alot of Norton. Norton Antivirus, Nortion internet security and onboard LAN and Onboard Vidio, which is taking 64 megs of my ram (Shared Memory" Slow performance, slow response to opening progs, and slow response to internet. I have cable. If I uninstall all Norton, and replace with Avast and Sygate firewall, Would that help? ALSO, if I disable onboard video in the bios, will it allocate that 64 megs to the system or reserve it only for onboard video? I have a Diamond Stealth s540 32 meg AGP graphics card that I could put into it. Not sure what to do yet. Need a performance increase. 3.20 gigs should run circles around my Athlon 750 Slot A 256megs of PC-133 SDRAM but it dont even come close to doing that. Advise? Suggestions? thought I should ask for advise before I make any changes. Have run Nortion systerm works and also system mechanic on Compaq, still dont notice much performance increase. I have an Idea that if I take all Norton software out, that will solve half my problem, but wanted to make sure. I can re-install it if I want to with the recovery CD. Thanks for any advice. It a Compaq Persario SR1803WM. I will NEVER get a store bought computer again.. Loaded with a bunch of junk I will never use.
Acer Aspire, M1100 Windows Vista Home Premium
Mombo323 is offline   Reply With Quote
Old August 24th, 2006, 10:51 AM     #2 (permalink)
SoMuchAnime-SoLittleTime
EXreaction's Avatar
Yes, removing Norton and using Avast and Sygate instead will be much faster.
If you have some extra time you could backup all your data, and then reformat(though Norton might get installed when you use a recovery disk, if it does you will have to use the Norton removal tool to get rid of everything).
The worst thing about Norton is when you uninstall that POS you still don't get rid of everything. It leaves a bunch of crap behind.
My photography: Flickr
Lithium Studios - phpBB3, PHP, and Web Development
Old August 24th, 2006, 12:13 PM     #3 (permalink)
Mombo323's Avatar
Where do I get this Norton Removal tool?
Old August 24th, 2006, 02:28 PM     #4 (permalink)
EXreaction's Avatar
If you have the versions listed on the page you can use this one:
http://www.softpedia.com/get/Tweak/U...val-Tool.shtml
Otherwise if you have a newer version you will need a different removal tool...
just built a pc... skylerhall General Tech Discussion 12 July 1st, 2006 11:47 AM
I just built a new PC need help splatfreak Technical Support 5 April 16th, 2004 07:40 AM
just built my new PC...what else do i need and how is it so far? Bleed Blue General Tech Discussion 6 December 2nd, 2003 09:31 PM
Alienware vs. self-built TOAD6147 General Discussion and Buyer Guidance 6 July 30th, 2003 03:12 AM
What have I built? Jarhed7276 General Tech Discussion 4 April 28th, 2003 08:47 PM
Is It Just Me? (2849)
Obama the Muslim (12)
Print spooler problem (10)
Display shows 3x5 inch in middle of s.. (2)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (33)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
