Vista RC-1 Dual Boot Problem  | | |
August 30th, 2006, 09:55 PM
I just installed Vista RC-1 in replace of my Vista Public Beta 2 and I still have my XP Pro on a seperate partition on my hard drive.
When booting up the computer it never gives me the option to pick my operating system and when I go into my startup settings it only says that I have Vista on my computer.
I know for a fact that XP is still on there because all of my files still exist of that partition. Under the startup settings, it is set to give me 30 seconds to choose between my OS's but it doesnt recognize my XP.
Does anyone have any clue how to fix this so I can boot both OS's? |
August 30th, 2006, 10:03 PM
so you can't get into XP?
__________________ KN1-Extreme amd althlon64 X2 4800+
2gig DDR400 memory 2 80gig sata drives radeon X850XT |
August 30th, 2006, 10:09 PM
Yes. Sorry if I was unclear as to what my problem was.
Since the computer does not recognize my XP I does not give me the option to boot it when the computer is started. |
August 30th, 2006, 10:14 PM
if you have the XP disk, put it in and start recovery console,
and type in Bootcfg /list
and see if it lists both OS's not sure what it will do about vista though |
August 30th, 2006, 10:18 PM
Since I just installed Vista I have no problem if anything happens to that partition because I can just re-load my public beta 2.
I would just like to be able to access my XP again.
Where do I load the recovery console from though... I dont see the option on the CD? |
August 30th, 2006, 10:21 PM
when it starts to install XP it will ask if you want to fix an existing windows |
August 30th, 2006, 10:23 PM
Will that affect any of the information I have stored on that partition? |
August 30th, 2006, 10:35 PM
hold on I think you can fix this in vista |
August 30th, 2006, 10:37 PM
ok go into control panel, and go to administrator tools,
click on system config, go to boot, and see if XP is on the list |
August 30th, 2006, 10:40 PM
No it does not show up on the list. |
