Thread: delete hard drive
October 3rd, 2006, 03:00 PM #1Junior Member
- Jul 2006
- 12
delete hard drive
How do I delete my entire contents of my hard drive?? I am having several problems with my computer and rebooting and reformatting. I really need to delete my entire contents of my computer and then try to reinstall windows after that.
THanks
October 3rd, 2006, 03:08 PM #2
What windows verison did you want to reinstall?
October 3rd, 2006, 03:15 PM #3
Ive heard KillDisk is a good program for your need.
Although, you shouldnt need to use such a program when reformatting.
October 3rd, 2006, 03:45 PM #4Junior Member
- Jul 2006
- 12
I need to reinstall XP onto my computer. The reason why I have to try to delete my entire contents is because Im having a really big problem getting the reformatting process to work correctly. I have a SONY Vaio and my recovery disks were not working, so I tried to reformat using my friends XP disk with my serial number, it worked, but now my computer is really messed up. I can't access the internet from it, nothing is on there and its just not right in any way. So I wanted to try to delete my hard drive and then go from there.
October 3rd, 2006, 03:46 PM #5
October 3rd, 2006, 04:24 PM #6
internet might not be working because you dont have the network adapter driver
October 3rd, 2006, 05:05 PM #7
What do you mean by not right, it does not have the same stuff on it, that it did with your restore disk,
Your restore disk may have some utility’s on it, and some programs like MS works, or MS money,
Maybe some antivirus program, firewall maybe,
What is your restore disk doing that it don’t work?KN1-Extreme
amd althlon64 X2 4800+
2gig DDR400 memory
2 80gig sata drives
radeon X850XT
October 3rd, 2006, 07:10 PM #8
You need to download and install all the drivers after reformatting. Such as network, video, sound, etc.......
Reformatting takes more than inserting a single OS cd.....
October 4th, 2006, 04:35 AM #9
For Sony VAIO you can install XP using any XP CD and the installation key that you receive with your computer and then you should have another CD with all the drivers on it so that after XP is there, install all the drivers using the second CD and it should be working like new
Their web site is also having the drivers for your computer so a little research and you'll be fine....
October 4th, 2006, 10:09 PM #10
October 5th, 2006, 01:47 AM #11Junior Member
- Jul 2006
- 12
Hey. I remember you trying to help me out before on this problem, thanks for sticking with me on this one. I finally got XP to format properly, but I STILL can't load the drivers onto my computer. When I go to install them, it throws up the message that the program was not intended to run on my model of computer. So, I still can't install anything, have no net, and nothing really works since I have virtually no drivers. I clean swiped the hard drive before I installed XP. I don't know what else to do, any more ideas to help me out???
how to delete 1 of two operating systems on a partitioned drive
By slider69 in forum Technical SupportReplies: 13Last Post: October 8th, 2007, 05:39 PM -
Hard Drive Temps?Do i need hard drive coolers?
By gipanizer in forum Processors, Memory, and OverclockingReplies: 0Last Post: January 19th, 2005, 08:17 PM -
How do I completely delete everything on my Hard Drive?
By PC-HAngover in forum Storage RelatedReplies: 16Last Post: May 20th, 2004, 02:23 PM -
Will a slow hard drive decrease performance of a faster hard drive?
By ninjamyst in forum Storage RelatedReplies: 7Last Post: May 5th, 2004, 08:18 AM -
How do you use dd for copying smaller hard drive to larger hard drive?
By Jüš† ä gü¥ in forum Linux and UnixReplies: 1Last Post: November 20th, 2003, 04:59 PM
ITS MY PARTY AND I CAN CRY IF I WANT TO! Rest day, that means 20 minutes of cardio in the am and pm! yay! Doing the Windows Azure training today, should be interesting since I work with AWS so...
