Thread: changing default shortcut paths
January 24th, 2007, 10:53 AM #1Member
- Dec 2004
- Location
- Golden, CO
- 138
For the default shortcuts, i.e. My Documents, My Music etc.... can you change the paths?
for XPSi vis pacem, para bellum
January 24th, 2007, 11:17 AM #2
right click on the my documents folder and click properties. from there you should be able to set where you would like it located
January 24th, 2007, 01:17 PM #3Member
- Dec 2004
- Location
- Golden, CO
- 138
being that im not a complete ass I tried that alread, and the path was static and couldn't be changed.
I know at work on my 2000 OS it is as simple as the right click > properties and entering a new path... but XP didn't work that way.Si vis pacem, para bellum
January 24th, 2007, 01:55 PM #4
Right click > properties > Use the find target button. That's what I did to move My Documents to my D: drive. (after moving the folder in safe mode)
If you want to use a different folder for documents (eg: use "Data" instead of "My Documents") click the Move... button.
Tip: create / move the folder first, then move the target. (I only say this because I tried this once, when my mind blanked, and windows wasn't happy.)Job hunting is a full time job.
January 24th, 2007, 01:59 PM #5
You can also change the paths using the Registry Editor.
Move the folder to where you want, then go in the registry and do a search of 'My Documents', 'My Pictures', 'My Music', and 'My Videos' and change their paths to what you want.
I have all those on my D drive and it works great, lasts long time.This signature intentionally left blank.
January 24th, 2007, 05:28 PM #6Member
- Dec 2004
- Location
- Golden, CO
- 138
ha, maybe registry will have to be the way to go, because right-clicking the My Music folder, its a static path, it cant be changed. there is no target, or find target like for my documents.
January 25th, 2007, 08:50 AM #7
January 25th, 2007, 01:47 PM #8Member
- Dec 2004
- Location
- Golden, CO
- 138
January 25th, 2007, 03:03 PM #9
How change lots of Windows default paths; how remove Wins default programs?
By Wai_Wai in forum Applications and Operating SystemsReplies: 12Last Post: July 24th, 2004, 02:36 PM -
Changing an Excel keyboard shortcut
By SpiffGQ in forum Applications and Operating SystemsReplies: 1Last Post: July 15th, 2004, 10:48 PM -
changing default WM with vnc
By BobOmega in forum Linux and UnixReplies: 2Last Post: June 13th, 2004, 01:59 PM -
Changing Default Directory?
By PeterGriffin in forum General Tech DiscussionReplies: 10Last Post: October 21st, 2003, 08:35 PM -
Changing Default Browser??
By Tomteriffic in forum Technical SupportReplies: 4Last Post: December 4th, 2001, 08:43 AM
I used to get some bad connection ALL the time. Turns out the problem was because I had a Netgear router and a D-LINK USB stick. I bought a D-LINK router and it works fantastic. Netgear sucks.
signal enhancer?
