Results 1 to 5 of 5
    Jul 2007
    3
    Vista upgrade problem
    Hello, This is my first post so, please, be gentle.
    I am working with a compaq presario SR1630NX
    Athlon 64 3500+
    512MB of PC3200 DDR
    Did the "upgrade" of Vista from xp pro today. It went perfect up until the very end. As I went to log on for the first time, I clicked my username, the screen went black and the computer rebooted.
    It restarted and gave me this error
    get_cdinfo (F3), int 13/ 4B01 (F3), err=1, drive=F2, 1(B1), err=1, drive=b1,
    That disappears and it says..
    Booting GRLDR
    Resetting the bootdrive...success
    Turning on gate A20...Success
    Then that disappears and it says...
    Boot drive=80, intb/4b01 (80), err=1, drive=80, notct
    get_cdinfo(f1), intb/4b01 (F1), err=1,drive=f1,
    Once again that disappears and I get
    ACPI
    Vista loader 2.1.2
    Starting cmain()...open/default... int 13/41 (80), version=AA300005,
    GRUB4DOS 0.4.3 2007-03-13, memory 638k/455m codeend:0x3d7bc
    Then, just for a split second I see some more references to (int_13) and the number 80, and NTLDR, but it goes by so fast I cant read it.
    Then for just another second it says
    Done!
    fallback 1
    Find --set-root /bootmgr
    see the attached photo for what happens next for about 8 seconds and then reboots to start the whole process over again.
    Any help at all is greatly appreciated.
    Caveat Emptor Rootstonian's Avatar
    Mar 2005
    Out of my mind
    3,350
    Cool, the Vista "Matrix" screen.
    I've yet to do a Vista install LET ALONE an Upgrade (not for a least 12 months to see if they get the kinks worked-out).
    I hope you have your original XP disk or made a backup image of your drive you can recover.
    Can you boot off the Vista Upgrade disk? Have you tried the "F8" go into Safe Mode and have a look around?
    Jul 2007
    3
    the last straw
    I guess trying to install vista was the last straw on this hdd.
    I finally gave up trying to fix it. Earlier I ran FDISK and deleted the existing partition. Resarted and created a new partition encompassing the whole hdd. Restarted again and formatted. Restarted again and ran fdisk to make the partition active and thats when fdisk started reporting that drive 1 could not be accessed.
    Ran a couple of Debug routines to erase the whole hdd and sector 2. Rebooted and ran fdisk again. Still reporting that drive 1 is inaccessable.
    Guess its time for a new HDD.
    Gonna try to do a fresh install of Vista on the new HDD.
    Jul 2007
    3
    Get this.. I was about to give the dead hdd to a friend to massacre it when I noticed the jumper was on cable select. DUH *SMACK*! Put it on master and creating the new partition now... Still gonna try a fresh install :P
    Nov 2006
    179
    vista upgrade
    I did an upgrade of vista yesterday with no problems
  1. Vista upgrade probs?
    By buildrebuild in forum Applications and Operating Systems
    Last Post: July 22nd, 2007, 02:34 PM
  2. Windows Vista - Never Upgrade !!!
    By fakan in forum Applications and Operating Systems
    Last Post: February 26th, 2007, 10:21 AM
  3. Vista + Upgrade = New License
    By washe in forum General Tech Discussion
    Last Post: October 20th, 2006, 04:43 PM
  4. Upgrade to Vista: Is It Worth It??
    By bolebec in forum General Tech Discussion
    Last Post: August 13th, 2006, 01:01 AM
