Thread: Direct Connect Question
April 19th, 2002, 10:06 AM #1Registered User
- Oct 2001
- 4,097
Are there any Spyware issues with Neomodus Direct Connect ?
Under licence it said Adware. What does that mean ?.
Thanks.
April 19th, 2002, 10:13 AM #2
that means it probably will put spyware on your system. i suggest you download ad-aware and scan your system after you install this software. beware though that sometimes it will cause your program to stop functioning, although there are several "dummy" spyware files that will prevent this...
April 19th, 2002, 10:19 AM #3
no there is no spyware
Lots, after you feed it up some.
