Optical Drive disapears
Currently Active Users: 1324
Discussions: 200,928, Posts: 2,379,144, Members: 246,295
Old February 6th, 2008, 10:43 AM   Digg it!   #1 (permalink)
uninstall.exe's Avatar
Send a message via AIM to uninstall.exe
Here is my system first off...
Intel Quad q6700
Intel DG33tl
2 X SATA 80g ( no raid)
Sata 20x burner
4 gigs of 800mhz ram
EVGA 8800GTX
Vista home Prem
Anywho most of the time my optical drive doesn't show up in device manager or even my computer thus i cannot use discs in it. I googled it and found the guide that told me to edit the registry, i followed the guide but i don't have the upper or the lower in my registry file. Anyne have another way that I can fix this.
- The drive is good
- No raid set up
- Bios shows it
- Everything is plugged in correctly
uninstall.exe is offline   Reply With Quote
Old February 6th, 2008, 01:36 PM     #2 (permalink)
THE Gimp Clown Fish!
nemowolf's Avatar
is the optical IDE or SATA?
Old February 6th, 2008, 01:46 PM     #3 (permalink)
SATA
Old February 6th, 2008, 03:00 PM     #4 (permalink)
did it work before?
try different power cable.
test with other drive if you have one.
try different sata onboard.
or switch sata cable.
3sweepers is offline   Reply With Quote
Optical Drive Brand Rec papawealey General Tech Discussion 3 July 20th, 2007 12:19 PM
problem with my optical drive A#1 Technical Support 5 April 30th, 2006 10:36 PM
Optical drive miriam Technical Support 19 May 14th, 2005 12:37 AM
Harddrive disapears? Phibz// Technical Support 5 January 30th, 2005 02:46 PM
Is It Just Me? (2867)
Obama the Muslim (14)
Regular Build (2)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
