Join TechIMO for Free!
Currently Active Users: 1898
Discussions: 181,064, Posts: 2,164,878, Members: 223,743
Old May 3rd, 2008, 12:46 PM   Digg it!   #1 (permalink)
Registry editing problem
Hi
I was editing a friends registry because she couldn't change her homepage (I tried all the usual things first). I deleted the Start Page key. When I went to add a new Start Page key, the regisrty allows me to create it, but does not allow me to edit the key. So the start page is blank - but we can get on the net by typing a web address. Any ideas as to how I can get the Start Key edited?
Thanks in Advance
Arjay
While one person hesitates because he feels inferior, the other is busy making mistakes and becoming superior
Arjay13 is offline   Reply With Quote
Old May 3rd, 2008, 01:56 PM     #2 (permalink)
BipolarBill's Avatar
Firstly, the probable reason for the inability to change the homepage was malware. Deleting and re-creating registry keys would not fix that underlying problem. If the system is slow and/or she's getting pop-ups, the system needs to be scanned and cleaned of spyware. Use Ad-Aware and Spybot Search and Destroy for this. Scan for viruses with AVG:
http://free.grisoft.com/
In the meantime, she can download and use Firefox. It's a safer and better way to surf the Net anyway:
www.mozilla.com
MCSE, MCP, MVP and nut job
BipolarBill is offline   Reply With Quote
Old May 3rd, 2008, 02:09 PM     #3 (permalink)
she has norton internet security running at all times - I checked the logs and it hasnt seen any malware recently and it last performed a full scan last week - still doesn't help me edit the registry
Old May 3rd, 2008, 02:32 PM     #4 (permalink)
NIS is not "all that". It's fine for AV in most cases, but it's not good with spyware. You need to scan with another because a locked homepage is not normal - unless it's locked by NIS, SpywareBlaster or another anti-malware program. You need to address this issue because you will get nowhere until you do.
We can't scan for you. You have to double-check yourself.
As I've said, she can get full function with Firefox in the meantime. Opera is another option.
The only other methods I know of fixing this problem are:
1. Reinstalling IE7
2. Repairing Windows
3. Reinstalling Windows
You may have to do one of those even if this is malware, but "first things first".
System Restore will restore the registry key, but it will not fix the homepage lock.
Old May 3rd, 2008, 02:35 PM     #5 (permalink)
That's a thought - check NIS settings to be sure that it isn't locking the home page.
Old May 3rd, 2008, 07:41 PM     #6 (permalink)
btw - there are multiple users on this machine and only one has the problem so I tyhink NIS is not the issue but I will check that. It'll take a couple of days since she is not local - thanks for the input!
Old May 3rd, 2008, 08:04 PM     #7 (permalink)
If the user is logged on as a Guest, she can't save any settings. If this is a work PC and she doesn't have Admin privileges, the same applies.
Old May 3rd, 2008, 10:11 PM     #8 (permalink)
evereddie's Avatar
Try running 'Hijack This'.
evereddie is online now   Reply With Quote
Old May 4th, 2008, 04:36 PM     #9 (permalink)
The other 3 users can change the start page so I don't think privileges is the issue. She is going to run Adaware and Spybot Search and Destry then try to reset IE7 to its default settings.
Still, why can't I edit the Start Page key? You think that malware is preventing me from doing that?
Old May 4th, 2008, 04:39 PM     #10 (permalink)
Yes.
If it's only happening in her profile, you can always create a new one for her.
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Suggestion for Registry search & editing tool videobruce Applications and Operating Systems 0 January 20th, 2008 11:54 AM
Editing registry. pjaj Applications and Operating Systems 6 May 18th, 2005 01:48 AM
PLEASE HELP!!! REGISTRY problem kevincassels Technical Support 5 December 19th, 2003 10:09 AM
CD/Registry Problem tigerpilot Technical Support 7 September 22nd, 2003 02:50 AM
confusion on registry editing draboo Applications and Operating Systems 7 April 6th, 2002 05:48 PM
