May 7th, 2008, 08:30 AM
| dos commonds are not running hi friends,
i have a problems while running dos commonds, most of them even help, are not recognized as external or internal commonds.i dont know any setting is to be done or anything else??please help me out anyway
regards
san |
May 7th, 2008, 09:18 AM
| | In DC Hell
| type this
echo %PATH%
echo doesn't work either?
cd c:\windows\system32
then try again
I have a feeling your PATH env variable is hosed. |
May 7th, 2008, 11:14 AM
| yeah.!! its pointing to java directory as per my requrement i have set it to point to.
is there any way to make the system point to system32 directory as well as java home directoy by setting anyway? |
May 7th, 2008, 03:13 PM
| | Ride 'em Cowboy
| Which Operating System are you running?
What commands are you attempting to run?
If Win XP and you click on START->RUN are you using the correct CMD or the incorrect Command to get to the DOS prompt? |
May 8th, 2008, 12:21 AM
| windows xp sp2
and evrything else is correctly running |
May 8th, 2008, 12:32 AM
| | Banned
| FWIW, I believe the cmd prompt is not the same as true DOS mode..
What Steve R Jones asked, "What commands are you wanting to run"??? |
May 8th, 2008, 12:37 PM
| | Super F@D Folder
| I think vass has it. He set the path to point to his java folder...
you need to put a ';' between entries in order to add multiple entries. When you deleted your old entry, you deleted the path to all your commands.
set path to Code: C:\Windows\System32\;C:\Windows\;C:\Windows\System32\Wbem then put a ; and add your java path in if you still want it. |
May 10th, 2008, 08:46 AM
| | ATI 4850 FTW!
| Quote:
Originally Posted by sr71000 I think vass has it. He set the path to point to his java folder...
set path to Code: C:\Windows\System32\;C:\Windows\;C:\Windows\System32\Wbem then put a ; and add your java path in if you still want it. | If only you could open a command line in the directory after you are in the directory.
The meek shall inherit the Earth. The powerful shall extort it.
May 10th, 2008, 10:48 AM
| | In DC Hell
May 10th, 2008, 01:16 PM
| | Super F@D Folder
| you don't have to be in the command line to set your path environment. You do it from control panel -> system -> advanced -> environment variables. |
