May 14th, 2008, 10:01 AM
| Need help for super slow XPpro (hijack log)
Windows XPpro. I've had this probelm a long time & I can't really say what caused it. I did install System Mechanic 7 & let it make some changes. I've since had it undo all of the registry changes that it had made(as far as I know). Working on it SO time consuming. I really don't want to reinstall windows. My windows disk wont let me do a repair - it reports that the installed version is newer than the disk. I quess because of updates.
SYMPTOMS: When I move the mouse pointer over an icon on the quick launch bar, it does not immediately become highlighted. In fact (I just timed this), it took 2 minutes for the icon to become highlighted then I clicked on the icon and it took 3 minutes for the application to open.
Once an application opens it operates fine - normal speed & responsiveness.
I can end the explorer.exe process in the process window of the task manager and restart it in the application window of the task manager. Then if I quickly attempt to start an application using the quick launch bar, it is responsive.
No aplication/process seems to be tying up the processor according to the task manager. It usually shows >90% on 'system idle process'. The hard drive is not excessively busy either.
If I attempt a restart Windows reports that explorer.exe is not responding.
END SYMPTOMS Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 8:15:03 AM, on 5/14/2008
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\iolo\common\lib\ioloServiceManager.exe
C:\Program Files\Common Files\McAfee\HackerWatch\HWAPI.exe
C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
c:\PROGRA~1\COMMON~1\mcafee\redirsvc\redirsvc.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
C:\Program Files\McAfee\MPF\MPFSrv.exe
C:\PROGRA~1\McAfee\MPS\mps.exe
C:\Program Files\McAfee\MPS\mpsevh.exe
C:\Program Files\iolo\System Mechanic 7\SMSystemAnalyzer.exe
C:\Program Files\Winamp\winampa.exe
C:\PROGRA~1\Ahead\Ahead\data\Xtras\mssysmgr.exe
C:\Program Files\FinePixViewer\QuickDCF.exe
c:\PROGRA~1\mcafee.com\agent\mcagent.exe
C:\PROGRA~1\COMMON~1\McAfee\EmProxy\emproxy.exe
C:\PROGRA~1\McAfee\MSC\mcpromgr.exe
C:\Program Files\Microsoft Office\OFFICE11\WINWORD.EXE
C:\WINDOWS\explorer.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - c:\PROGRA~1\mcafee\VIRUSS~1\scriptcl.dll
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [REGSHAVE] C:\Program Files\REGSHAVE\REGSHAVE.EXE /AUTORUN
O4 - HKLM\..\Run: [SMSystemAnalyzer] "C:\Program Files\iolo\System Mechanic 7\SMSystemAnalyzer.exe"
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [WinampAgent] "C:\Program Files\Winamp\winampa.exe"
O4 - HKCU\..\Run: [PhotoShow Deluxe Media Manager] C:\PROGRA~1\Ahead\Ahead\data\Xtras\mssysmgr.exe
O4 - HKCU\..\Run: [NBJ] "C:\Program Files\Ahead\Nero BackItUp\NBJ.exe"
O4 - Global Startup: Exif Launcher.lnk = C:\Program Files\FinePixViewer\QuickDCF.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O16 - DPF: {05CA9FB0-3E3E-4B36-BF41-0E3A5CAA8CD8} (Office Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=58813
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/wind...?1202857604257
O17 - HKLM\System\CCS\Services\Tcpip\..\{4E0F22CE-E1A8-46EB-8083-0AB5AD36A022}: NameServer = 68.87.64.196,68.87.66.196
O17 - HKLM\System\CS1\Services\Tcpip\..\{4E0F22CE-E1A8-46EB-8083-0AB5AD36A022}: NameServer = 68.87.64.196,68.87.66.196
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: McAfee E-mail Proxy (Emproxy) - McAfee, Inc. - C:\PROGRA~1\COMMON~1\McAfee\EmProxy\emproxy.exe
O23 - Service: iolo FileInfoList Service (ioloFileInfoList) - Unknown owner - C:\Program Files\iolo\common\lib\ioloServiceManager.exe
O23 - Service: iolo System Service (ioloSystemService) - Unknown owner - C:\Program Files\iolo\common\lib\ioloServiceManager.exe
O23 - Service: Logitech Bluetooth Service (LBTServ) - Unknown owner - C:\Program Files\Common Files\LogiShrd\Bluetooth\LBTServ.exe (file missing)
O23 - Service: McAfee HackerWatch Service - McAfee, Inc. - C:\Program Files\Common Files\McAfee\HackerWatch\HWAPI.exe
O23 - Service: McAfee Update Manager (mcmispupdmgr) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcupdmgr.exe
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
O23 - Service: McAfee Protection Manager (mcpromgr) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcpromgr.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
O23 - Service: McAfee Redirector Service (McRedirector) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\redirsvc\redirsvc.exe
O23 - Service: McAfee Real-time Scanner (McShield) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
O23 - Service: McAfee SystemGuards (McSysmon) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
O23 - Service: McAfee Personal Firewall Service (MpfService) - McAfee, Inc. - C:\Program Files\McAfee\MPF\MPFSrv.exe
O23 - Service: McAfee Privacy Service (MPS9) - McAfee, Inc. - C:\PROGRA~1\McAfee\MPS\mps.exe
End of file - 5851 bytes
Any advice will be greatly apreciated. |
May 14th, 2008, 10:05 AM
| | Banned by everybody
if it really takes THAT long, you can take an eternity to find it.
best and fastest way by far is to save your data and do a re-install.
But if you really don't want to, please post your system specs, that might give a clue as to what is going on.
PS McAfee is a huge systemhog, if you have an already slow pc in regards to specs, then that might also slow it down quite a bit
Antec P180b, AMD X2 3800+ @ 2.7Ghz
DFI Lanparty Ultra-D, 2Gb DDR540
2 x 160Gb SATA, X1950XT 256MB
May 14th, 2008, 10:28 AM
Intel D845WN with a 2Ghz PeniumIV
1G RAM
I cant get to the system manager to get the details.
ATI AGP video board
It has previously ran fine with all current software and hardware.
It's got a few years on it but speed has not been an issue - before this problem.
I highly suspect that I let System Mechanic do something that I shouldn't have.
Something in the registry. |
May 14th, 2008, 11:46 AM
You can always attempt a system restore previous to System Mechanic to see if that'll take care of things. I honestly never trust any registry cleaner as, unless you know what you need to remove via registry, Windows XP and on really manages itself for the most part. If you have computer slow downs, it's best to minimize processes, startup, and system services rather than scan through the registry. Keep this in mind.
Often registry cleaning software will keep registry backup files automatically also, seeing as you can really mess something up when dealing with the registry. If System Mechanic has made backups, you can always restore it from one of those, too.
__________________ Intel Core 2 Quad Q6600 OCed 50% (3.6GHz) | ASUS P5K Deluxe w/ WIFI | G.Skill 4096MB (4x1024MB) RAM | Foxconn GF8800 GTS 640MB | WD Raptor 150GB |
