Thread: Dual Boot WinXP System?
June 29th, 2008, 01:47 PM #1Junior Member
- May 2003
- Location
- Leeds, UK
- 28
I have WinXP Home on my PC and I want to install another version of WinXP Home on the same machine (different disc though so licence number is not the same). How do I do this? I have another machine with two versions on and when booting up the machine it offers the choice of which OS you want. I didn't set this PC up though so don't know how it was done. Do I just put the WinXP CD in the drive or what? Also I've been told I need to partition my C drive when installing two copies, but on the PC I have that already has two copies, it doesn't appear that the C drive is partitioned at all!
Cheers.
-Rob
June 29th, 2008, 02:03 PM #2
It's never a good idea to install two Windows operating systems on the same partition. The reason is that there are two Windows Registries and anything you scan the registry with will get confused and possibly edit the wrong one or both - possibly messing up the one that you're not in at the time.
It's absolutey impossible to have two versions of the same OS on the same partition. Forget that.
You *must* partition the drive.
Partition Logic
You have two choices for installing a second XP.
1. Insert the CD while in Windows and install. Select Advanced and choose to install it in another location. Select your new partition there.
2. Boot from the CD and install. Choose the appropriate partition when prompted. Ignore the repair screen.MCSE, MCP and nut job
Change boot drive in dual-boot system
By ElViti in forum Applications and Operating SystemsReplies: 15Last Post: June 30th, 2008, 07:15 AM -
Dual OS: Boot Camp & WinXP
By Brangwen in forum Applications and Operating SystemsReplies: 3Last Post: March 23rd, 2007, 01:19 PM -
dual boot: WinXP and OSX?
By Acid_ICE24 in forum Applications and Operating SystemsReplies: 7Last Post: October 26th, 2005, 10:26 PM -
How to remove a boot partition in a dual boot system?
By Balbaz in forum Applications and Operating SystemsReplies: 3Last Post: July 11th, 2004, 07:03 PM -
Win2k and WinXP dual boot
By implexant in forum Applications and Operating SystemsReplies: 5Last Post: January 4th, 2003, 11:50 PM
I really want Pacific Rim to be Cloverfield 2. That would be so badass!
