Thread: XP Pro repair utility
May 8th, 2002, 12:16 PM #1
Has anybody used the repair utility that comes on the cd? IE6 no longer loads when I try to open it. Instead I get the error and the screen to submit it to M$. I started the repair utility, but I have no idea how to use it.
May 8th, 2002, 12:28 PM #2
IE6 has built in repair software, In the add/remove control panel click to remove it and then when it ask click the "Repair" option, That should fix it if it is a IE problem.
May 8th, 2002, 12:32 PM #3
You cal also always try SFC (system file checker). It has cleared up a couple of error I was receiveing ("Windows has recovered from a major error on boot")
May 8th, 2002, 12:35 PM #4
http://support.microsoft.com/search/...;en-us;Q318378
That's what I had to do,"Sometimes life is just what we make it."
May 8th, 2002, 03:38 PM #5
You're not going to be able to go the "Add/Remove" route, due to the fact the I.E. 6 is the base for Windows XP. You'll be able to do that later when you install future versions of I.E., but not now.
You're either going to have to try what Surreal suggested, or boot to the XP CD and repair your installation.
May 8th, 2002, 04:05 PM #6
you can reinstall IE in Windows XP by clicking Start, Run and entering the following command:
rundll32.exe setupapi,InstallHinfSection DefaultInstall 132 %windir%\Inf\ie.inf
You will need to have your XP CD available
pay attention to the syntax"the chief cause of problems is solutions!"
Watch Man of Steel Online Free Directed by Marc Forster, WWZ is easily one of the most entertaining and epic zombie films ever made. Now this being said, many zombie fanatics will disagree, I know...
Watch The Internship Online...
