bat file problem running xcopy
Currently Active Users: 1713
Discussions: 195,857, Posts: 2,327,984, Members: 241,383
Old November 4th, 2008, 02:56 PM   Digg it!   #1 (permalink)
Hi, I'm running an XCOPY command within a bat file. The XCOPY takes several hours to run, lots of large files. Once it gets to the XCOPY, it copies all the files, but it does not continue to the next line in the bat file. It just stops. Any idea what is going on? Is there some sort of timeout? This is on a Windows 2000 server. The command looks like:
xcopy /O /Y E:\aaa\bbb\*.* E:\ccc\ddd\data 1>> E:\backup\log\backup_log.txt
Again, all the files are copied, but it doesn't execute the next line which is
echo . >> E:\backup\log\backup_log.txt
Any ideas?
Cdor is offline   Reply With Quote
Old November 4th, 2008, 04:53 PM     #2 (permalink)
Not sure what you >> are suppose to do....The following should work.
ECHO E:\backup\log\backup_log.txt
Steve R Jones is offline   Reply With Quote
Old November 5th, 2008, 08:26 AM     #3 (permalink)
does anyone know if there is a problem with bat files timing out? When I do the XCOPY, it takes about 4 hours. I am thinking that maybe the bat file times out and execution never returns to process the next few lines in the bat file.
Old November 5th, 2008, 08:39 AM     #4 (permalink)
I don't see how it can time out if you're getting all the files copied.
Could you live without the /O switch?
Approx how many files and what is the total size?
You might want to research RoboCopy that ships with Vista. It's much more powerful. You can get it as part of the tools here or copy it off a Vista machine:
Download details: Windows Server 2003 Resource Kit Tools
Old November 5th, 2008, 08:47 AM     #5 (permalink)
there are 71 database files, total of 14 gig. I'm thinking of adding the /C switch. Maybe there is some sort of error (although all the files are being copied)? I'd like to retain the /O switch since this is a database backup, unless there is some reason that I should drop it.
Old November 5th, 2008, 09:01 AM     #6 (permalink)
robocopy, or "Robust File Copy", is a command-line directory replication command. It was available as part of the Windows Resource Kit, and introduced as a standard feature of Windows Vista and Windows Server 2008.
Robocopy is designed for reliable mirroring of directories or directory trees. It has features to ensure all NTFS attributes and properties are copied, and includes additional restart code for network connections subject to disruption.
Robocopy is notable for capabilities above and beyond the built-in Windows copy and xcopy commands, including the following:
Continued here:
robocopy - Wikipedia, the free encyclopedia
Old November 5th, 2008, 09:30 AM     #7 (permalink)
is robocopy any faster than xcopy?
Old November 5th, 2008, 11:49 AM     #8 (permalink)
I've never used it. But
"Robocopy is notable for capabilities above and beyond the built-in Windows copy and xcopy commands"
sure would motivate me to at least try it.
You could do a test run with a small group of files.
Old November 5th, 2008, 01:14 PM     #9 (permalink)
Caveat Emptor
Rootstonian's Avatar
4 hours? 14 gigs? I take it you're not on a gigabit network LOL...my in-house moves 20 gigs in about 8 minutes!!!
Old November 6th, 2008, 11:10 AM     #10 (permalink)
Well actually ...., the entire script takes about 4 hrs and it shuts down lots of services including the Oracle Database. I'm not sure how long the copy piece takes. I'll have to put a time in the script. This is an old HP server, Proliant DL380 G3. The drive is an internal logical (partitioned) COMPAQ SCSI drive. But the copy is probably taking longer than normal because it's being copied to a compressed folder, which adds some overhead.
xcopy the newest file bilbonvidia Applications and Operating Systems 1 April 17th, 2007 01:06 PM
Running .exe's with Run As in a .bat file Sledgehammer Technical Support 3 December 4th, 2003 08:13 AM
Create a .bat file shotokan General Tech Discussion 10 May 28th, 2003 09:13 AM
running a .bat in win98... how do I? zskillz Technical Support 14 November 25th, 2002 02:20 AM
autoexec.bat file isup General Tech Discussion 16 October 24th, 2002 03:20 PM
Is It Just Me? (1445)
Palin Resigning as Governor (45)
Budget PC Build, first time - Need .. (14)
[F@H SPAM 28 JUN 09] Today's the da.. (136)
Looking for Some good PC games. (9)
Worth upgrading GFX card? (35)
Assosiations (20424)
build advice (19)
You guys might like this one (22)
Crap, my graphics have gone to hell (17)
4gb RAM (7)
Is this a decent gaming system??? (25)
Gigabyte 770 vs 790GX (cant decide) (7)
Toshiba Tecra A8 / Satellite pro A1.. (5)
Gaming Laptop (1)
Not enough RAM... (1)
wifes laptop (1)
Apple no longer using nVidia? (0)
build advice (19)
Desktop Computer on Laptop Screen (0)
Windows 7 Beta won't install (5)
internet connection is breaking (10)
please help (1)
What salary can I expect once I gradu.. (0)
Windows Product Key (5)
Weird Battlefield 2 errors (3)
ps3 connection- no video signal (1)
firefox 3.5 is slow to start (10)
Apple iPhone 3G S 32GB Unlocked (0)
Explorer page shuts down...HELP.. (0)
video card (2)
need a laptop (5)
Need Technical Expierience (77)
6 Quad/S SeriesMotherboard (0)
Trying to OC E7200 as much as possibl.. (3)
Up / down arrows jumps to bottom of p.. (7)
FS: Sony Memory Stick Pro Duo 1GB (0)
