XP upgrade problem
Currently Active Users: 2572
Discussions: 203,415, Posts: 2,407,339, Members: 248,936
Old December 5th, 2008, 10:41 PM   Digg it!   #1 (permalink)
XP upgrade problem
I tried to upgrade my wife's computer from Win 2000 to XP pro. Now it hangs in the middle of the install process and won't go any further. I have tried to reinstall several times and even told it to format the partition with no luck.
It finishes loading files gives a screen that says remove any disks from Drive A: then reboots. If I take out the XP setup CD, it goes to the opening XP screen witht he blue dots progressing across the "loading bar" below the logo. Those little balls go part of the way across and then they stop and it hangs. If I tell it to boot from the CD, it starts the setup process again.
Any suggestions will help!
Is there a partition program (preferably free) that I can burn to a CD and boot from that to make sure the drive is clean?
docbk is offline   Reply With Quote
Old December 6th, 2008, 09:47 AM     #2 (permalink)
BipolarBill's Avatar
Sure. Search Google for Partition Manager. Easeus makes it. You can also search for "boot and nuke". Another is Partition Logic.
I assume that critical data is either absent or already backed up?
MCSE, MCP, MVP and nut job
BipolarBill is offline   Reply With Quote
Old December 6th, 2008, 11:47 AM     #3 (permalink)
Pump you sucker! Pump!
Chuckiechan's Avatar
I sounds like you might have a memory problem. Try swapping out your ram.
"We shall fight in the air, we shall fight on the landing grounds, we shall fight in the fields, we shall fight in the hills -- for 18 months. Then we start packing for home." Krauthammer
Chuckiechan is offline   Reply With Quote
Old December 6th, 2008, 11:51 AM     #4 (permalink)
xp problem
I have tried to format the C drive using the command line and yet it seems to not completely clean the drive because when I try to reinstall, it never asks for my product key.
The data is on the same drive different partition.
Anymore thoughts?
Thanks to all.
Old December 6th, 2008, 11:56 AM     #5 (permalink)
Best To Avoid Me
Martoch's Avatar
Are you saying that you've tried to format the C drive from a command prompt while in the OS installed on that same C drive?
You can completely wipe your drive with Killdisk (free version)...you boot to a disc just as you requested.
Active@ Kill Disk. Hard Drives Eraser. Free Download.
Martoch is offline   Reply With Quote
Old December 6th, 2008, 12:13 PM     #6 (permalink)
If the version of XP that you have is a special version like Student or OEM like Dell, it may not require a key.
Also, look for hidden partitions like the Dell diagnostic partition. That may permit installation without a key too.
Old December 6th, 2008, 01:09 PM     #7 (permalink)
to F@H or not to F@H ?
Cmptr-Gy-Dv's Avatar
don't just format the partition, delete the partition and make a new one,
than do a fresh install,
i'm folding for techimo!! what are you doing?
Cmptr-Gy-Dv is offline   Reply With Quote
memory upgrade problem postalpete Technical Support 5 September 10th, 2008 12:20 PM
p4vmm2 upgrade problem imeg Technical Support 1 October 26th, 2006 01:52 PM
Memory Upgrade Problem jagee Processors, Memory, and Overclocking 6 April 18th, 2006 12:31 PM
Minor upgrade problem Maloc General Tech Discussion 5 February 5th, 2006 11:08 AM
motherboard upgrade problem ThePitt Technical Support 9 November 26th, 2003 02:35 AM
Is It Just Me? (3711)
nVIDIA GTX 260 vs ATI 5770 (5)
Superbowl commercials (The green po.. (15)
and she wanted to be VP? (34)
GPU upgrade from 8600 GT (9)
New PC Heavy Gaming Rig (8)
[F@H Chat]2/6/10 New thread for ya'.. (22)
Need for Speed Shift (7)
Best route for upgrade (several opt.. (5)
Motherboards with 2 PCIE x16 slots (8)
I want to buid a pc with this case (14)
Graphene transistors promise 100GHz.. (7)
Animated GIFs don't animate? (13)
Upgrading (5)
HD5870 Question (16)
[F@H Chat]2/6/10 New thread for ya' s.. (22)
Wireless G printer w/wrt160n (0)
SpeedFan Temp Monitor Help (3)
BSOD - IRQL not less or equal - HELP! (0)
Unable to find LAN (7)
Best route for upgrade (several optio.. (5)
should i upgrade whole pc or just vid.. (2)
WEBCAM / XP / XP64 / VISTA (7)
routers and switches OPERATING SYSTEM.. (0)
One dumb nube and a cisco 3550 (1)
120mm fan on top of case??? (12)
Is my hard drive going bad? Please h.. (2)
rsync over passwordless ssh in a cron.. (4)
Wii at buy.com for $374 - Carnival Sm.. (7)
Deleted email addy keeps bouncing bac.. (1)
Laptop - HDTV Connection Using HDMI C.. (1)
Video Format Total Solution: How to C.. (0)
How Good is This $450 MSI Laptop? (2)
wireless connectivity (0)
My 9400GT's fan is screwy (2)
